Piston pin question #81083
06/28/08 07:38 PM
06/28/08 07:38 PM
Anonymous OP
Anonymous OP
I'm going to change my pistons to the KB-107's and they have the floating pins.Do i have to get my rods bushed for floating pins or can i use them as pressed fit pistons.
Re: Piston pin question #81084
06/28/08 07:53 PM
06/28/08 07:53 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use can use them as pressed fit. You just have the pins installed in the rods with an interference fit and no keepers in the pistons. The pistons are designed to go either way.
I floated mine unbushed though. We've been doing it for years with no problems.
Re: Piston pin question [Re: MoparforLife] #81085
06/28/08 10:21 PM
06/28/08 10:21 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have a set of wiseco floating pin pistons in my truck that have been installed by pressing them in instead. Not worth the extra hassle and money to rework a set of stock rods for the floating pins. My crank grinder has been doing them this way since the 70's and it's never been an issue.
Re: Piston pin question [Re: Neil] #81086
06/28/08 10:35 PM
06/28/08 10:35 PM
Upper Midwest
Upper Midwest
There is no power gain with floating pins. The only gain is ease of replacement of a piston if needed. Also if a pin should score either in the rod or in the piston there is still one pivot point so it should not throw the rod. We floated as we had access to the pin hone so floated the rods.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Piston pin question [Re: MoparforLife] #81087
06/29/08 08:43 AM
06/29/08 08:43 AM
Anonymous OP
Anonymous OP
Thanks guys that is what i wanted to hear.
