Re: Dual quads vs Six pack
[Re: 73ChargerSE440]
#81041
06/28/08 07:02 PM
06/28/08 07:02 PM
Posts: 2,497 God's Country Maryland
GODSCOUNTRY340
My single 4bbl, 850 Holley out ET'ed my Six Pack by 4 tenths. When you think about it, the Six Pack came off the line on the center 2bbl (300cfm) where the 850 came off with 850cfm.
#81044
06/28/08 10:54 PM
06/28/08 10:54 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Dual quad for two years now. Swinger street car sleeper, 440, AT, PS, PB, AC, CC, lotsa TQ. Have zero tuning problems...it's just a four barrel until WOT. Having fun.
Russ n Virginia:)
BigBlock 74 Swinger
[Re: bb74swngr]
#81045
06/28/08 11:05 PM
06/28/08 11:05 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
By the way, my previous car was a 70 Chally 440 SP Vert with AT, PS, PB, and AC. Had zero tuning problems...it was just a two barrel until WOT. Had lotsa fun. They are both great!!!! Russ n Virginia:)
BigBlock 74 Swinger
[Re: bb74swngr]
#81046
06/28/08 11:51 PM
06/28/08 11:51 PM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
If we are talking about a stock set-up, street driven, you can't beat the six pack for driveability (cold start, road manners, mpg, and power). The factory dual quad setups are cold natured and tend to use more fuel, wot is great however.
When you start talking about after market intakes, carb options etc; sure you can out perform stock set-ups, and loose drivability in exchange for performance "sometimes".
In stock trim I prefer the sixpack, I have two currently and plan on adding a third. I was also planning on adding a crossram setup but it was for a road trip car and I've been thinking twice with fuel cost what they are.
I get 16.5 mpg if I drive sane with 3:54s in my GTX. I have heard 11 mpg with the 440 crossram.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
[Re: GTX70sixpack]
#81047
06/29/08 01:45 PM
06/29/08 01:45 PM
Posts: 4,761 Holland MI Ottawa
2boltmain
Holland MI Ottawa
The Edelbrock 2x4 set up offers awesome performance and eye appeal at half the price of a six pack set up. A single four will make as much as or more power (RPM or Team G?) but c'mon, single 4bbl V8s are EVERYWHERE.
Keep old mopars alive.
[Re: 2boltmain]
#81048
06/29/08 01:53 PM
06/29/08 01:53 PM
Posts: 1,261 ILL
mark7171
ILL
so. they could be on to something.
id go dual quad if i had to choose one or the other. a 4 bbl will win for most levels of play. ages 12 and up. batteries not included. run with adult supervision.
#81057
07/06/08 05:28 PM
07/06/08 05:28 PM
2boltmain
Holland MI Ottawa
Edelbrock actually reccommends 2 600cfm carbs on the CH-28. On both my 440s I have used 2 500cfm carbs and it worked FANTASTIC. If a person already has a 600cfm Eddy carb I would buy one more and call it good. Alot of small block chevy guys run dual 600s on their eddy 2x4 set up and claim success. My 360 will run an OFFY 2x4 and dual 500s.
#81060
07/09/08 03:33 AM
07/09/08 03:33 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
I would take the 2x4. I have the same. Run them the first season and I canīt be more happy. Tons of torque, great throttle response. 2x600cfm but still a little bit on the rich side. I wouldnīt use the bigger jets Edl delivers with the dual quad. I also do not like the comparison of the different intakes. The cam should be grinded to your specific needs. Mine is a solid flat tapped from Scott Brown. Awsome power! And cheaper then the 2x3. A friend of mine changed his 1x4 intake in his 68 charger to a 2x4 and he said it was like putting in another engine. Way better throttle response and awsome torque.
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: copchaser]
#81064
07/11/08 02:59 AM
07/11/08 02:59 AM
Den300
Hamburg / Germany
for a 541cui engine the ch-28 would be no good choice. and lots depends on the cam. i do not think you can compare 3 comlete different intakes with the same cam. they all have different "needs". it canīt be more different. a low rise dual quad and a tunnel ram. what about the torque?
Hamburg/Germany
