Re: torsion bar removal tool
[Re: 68 Sat]
#81000
01/05/11 08:56 PM
01/05/11 08:56 PM
Posts: 16,128 Mesa, Arizona
dart4forte
Mesa, Arizona
Don't waste your time with any other contraption then Hemigods removal tool. I used it last night to remove my torsion bars and it works liked a charm. Really well built and saved my ass. Just buy it
Just got mine the other day. Well made.
[Re: dOc !]
#81001
01/06/11 08:13 AM
01/06/11 08:13 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
There is NOTHING BETTER for removing a TB than a Miller tool.
I still have one, the allen bolts are a PITA though.
I'd rather back off the LCA nut and just break the bar loose that way, usally all it takes.
[Re: txterry2]
#81005
01/06/11 02:23 PM
01/06/11 02:23 PM
Posts: 948 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
I used a 1 inch cable splice and a 3 lb. hammer.
That's what I used too. Though with an 8 lbs sledge.
[Re: johnscudashop]
#81013
03/10/14 10:05 AM
03/10/14 10:05 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I am no means perfect , but I try to create a good product and service for the price
I have one and it WORKED when the others failed. Well worth the money when you take a swing with the BFH and that T-bar slides right out.
[Re: Publicbottle]
#2575158
11/07/18 01:46 AM
11/07/18 01:46 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Anything that clamps to the bar w/o marring its surface will work fine for this job....A pair of vice grips w cloth rags between the jaws and the bar can be hit and work fine.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
