Determining Correct Pushrod length #80894
06/28/08 02:23 PM
06/28/08 02:23 PM
idaho
77v-drive Offline OP
idaho
I am trying to order the correct pushrods for my 440. 440 source heads, Comp Cams pro magnum rockers, Engle K-60 hydrualic cam, Engle lifters.
Here is what I am doing is this right or wrong? 1-Put the cam on the base of the lobe. 2-Set the rocker adjuster to 1 1/2 threads showing. 3- Lengthen the adjustable pushrod until there is no movement and no collape of the lifter (the lifters are dry). 4-Measure the pushrod and add .030 to the length for preload. This is my first time doing this so any help/advice would be appreciated. Thanks.
Re: Determining Correct Pushrod length [Re: 77v-drive] #80895
06/28/08 03:20 PM
06/28/08 03:20 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I would say 0-1/2 thread showing than that leaves you with another 1/2 for lifter preload.1 thread total when done should be max showing.
Re: Determining Correct Pushrod length [Re: Scamp408] #80896
06/28/08 06:30 PM
06/28/08 06:30 PM
idaho
idaho
O.K., so only 0-1/2 thread showing. Does everything else sound alright?
Re: Determining Correct Pushrod length [Re: 77v-drive] #80897
06/28/08 08:23 PM
06/28/08 08:23 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
base circle cam,0 to 1/2 thread,extend pushrod.do not colapse lifter and do not add .030.When you adjust you will have close to 1 thread showing.Lifter preload is 1/4-1/2 turn from zero.
Re: Determining Correct Pushrod length [Re: Scamp408] #80898
06/28/08 08:52 PM
06/28/08 08:52 PM
idaho
idaho
Thanks, does 9.105 sound good? Cause that's what I come up with.
Re: Determining Correct Pushrod length [Re: 77v-drive] #80899
06/29/08 07:01 AM
06/29/08 07:01 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
All motors are diff. Trend pushrod are great people to deal with.
