B series motor identification #80883
06/28/08 01:23 PM
06/28/08 01:23 PM
NJ
440challenger Offline OP
NJ
I got a B series big block mopar from a friend.
on the side where the freeze plugs are it says 3614230
I would think this is a 361 but the date code on the motor is 1971. I didnt think the 361 was made in 71. 230 is a cold weather block correct? i thought it was a 400. now im all confused. any input? thanks guys!
Re: B series motor identification [Re: 440challenger] #80884
06/28/08 01:27 PM
06/28/08 01:27 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
230 is the 400 block, yep
Re: B series motor identification [Re: 440challenger] #80885
06/28/08 01:34 PM
06/28/08 01:34 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
you can see displacement too stamped at a side of dist hole. That could be a very earlier 400, since fist year to 400 was on 72 models
Re: B series motor identification [Re: NachoRT74] #80886
06/28/08 02:32 PM
06/28/08 02:32 PM
3614230 is the casting number for a 1972 400 block.
On a B engine, the displacement will be stamped on the machined area at the front of the block head surface where it sticks out for the timing chain housing, under the distributor.
