71 GTX Where is the shoulder hole for seatbelts ? #80873
06/28/08 01:15 PM
06/28/08 01:15 PM
Cleveland
sunroofgtx Offline OP
Cleveland
OK, I think the headliner installer marked the holes for the 3 point shoulder belt, but need to make sure before I put a hole in the headliner.. Is it near the middle of the rear 1/4 window ? Thanks.. I'm installing the XV Motorsports belts...
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 71 GTX Where is the shoulder hole for seatbelts ? [Re: sunroofgtx] #80874
06/28/08 01:32 PM
06/28/08 01:32 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
close to the end of quarter window.
Charger shown on pic. same to Plymouth.
Need pics for clips location ?
Re: 71 GTX Where is the shoulder hole for seatbelts ? [Re: NachoRT74] #80875
06/28/08 01:36 PM
06/28/08 01:36 PM
Cleveland
Cleveland
Wow, way back there ! It seems too far back.. Thanks for the pic. Just need the anchor point. I guess if thats where it is, thats where it is. Thanks very much, Rick Gorski
Re: 71 GTX Where is the shoulder hole for seatbelts ? [Re: sunroofgtx] #80876
06/28/08 01:55 PM
06/28/08 01:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yeah, that anchor point could became on a problem to aftermarket 3 points seatbels since stock are designed as a non retractable and separated shoulder belt. Thats up to 73 on all Mopars. ( and all American cars though )
74s are easier since they locate just right in the middle of both glasses, pretty much close at same height of floor retractor, since 74 shoulder belt is with a retractor hidden by lower quarter panel. This setup uses just one conector common to both belts
Re: 71 GTX Where is the shoulder hole for seatbelts ? [Re: NachoRT74] #80877
06/28/08 02:16 PM
06/28/08 02:16 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Yep that far back Rick. Just checked one of my 71's. About 8.5" back from the front edge of the quarter glass SS trim.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71 GTX Where is the shoulder hole for seatbelts ? [Re: moparmarks] #80878
06/28/08 06:34 PM
06/28/08 06:34 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
A little extra work but you may want to pull the trim off, peel back the headliner in the area and find the mount before you start punching holes.
Re: 71 GTX Where is the shoulder hole for seatbelts ? [Re: CYACOP] #80879
06/28/08 06:36 PM
06/28/08 06:36 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: 71 GTX Where is the shoulder hole for seatbelts ? [Re: CYACOP] #80880
06/28/08 09:44 PM
06/28/08 09:44 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
they can be touch from exterior... just explore with hands
Re: 71 GTX Where is the shoulder hole for seatbelts ? [Re: CYACOP] #80881
06/28/08 10:15 PM
06/28/08 10:15 PM
That's exactly how I did mine. Although I could feel where they were, I wasn't going to poke a hole through my new headliner until I was sure. Mark the coat hangers while you are up there. Just drive a screw into them and through the headliner when you find them, add hooks whenever you get the chance.
Re: 71 GTX Where is the shoulder hole for seatbelts ? #80882
06/28/08 10:16 PM
06/28/08 10:16 PM
Cleveland
Cleveland
Thanks a ton guys. The whole install went very smoothly.. I couldn't believe they were that far back.. Thanks a ton, guys. Rick Gorski
