What's the axle center register size? #80642
06/27/08 07:19 PM
06/27/08 07:19 PM
Seattle, WA
3
375inStroke Offline OP
Special needs person
3
Seattle, WA
What's the size of the center register on large bolt pattern axles? I assume it's larger than the small bolt pattern. Do other axles have different register sizes? Let's say one gets a set of 11" backing plates off a 9-1/4" diff, would the drum be too big? I got a set cheap, but the register looked huge, so I thought I would try the backing plates with a set of '60s C-body drums. Maybe it was my imagination. I'm used to looking at the small bolt rears.
Re: What's the axle center register size? [Re: 375inStroke] #80643
06/27/08 10:20 PM
06/27/08 10:20 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
All RWD Mopar 5 x 4.5" axles/hubs use the same register size.
