Re: Variable speed wiring
[Re: Shatar4]
#80570
06/27/08 03:43 PM
06/27/08 03:43 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Wiring is the same to all units, 2 and 3 speeds on B and E bodies. Difference is just on 72 and laters plugs due diff size and prongs distribution. 72 and later switches are smaller. But wires itself is the same, just plugs and prongs setup changes but is a year stuff not a speed stuff
EXTRA PRONG could it be ( not sure ) for ground reinforcement. doesn't plug to anywhere. Switch takes ground from chassis ( required ) 2 speeds doesn't need ground.
I just made the 3 speeds conversion on my 74 Charger from 2 speeds. I got 3 speeds 73 switch and 71 Variable speed switch. Decided to go with Variable since I got the right matching plugs for 71 setup.
simply use existing wiring and done
