440 oil pump change #80538
06/27/08 01:59 PM
06/27/08 01:59 PM
Ohio
moparrjm Offline OP
super gas
moparrjm  Offline OP
super gas
Ohio
Can a oil pump on a 71 Charger, 440 engine be changed without pulling the engine?
Re: 440 oil pump change [Re: moparrjm] #80539
06/27/08 02:03 PM
06/27/08 02:03 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
You should be able to get it out.
Take out the L/S motor mount bolt and raise it up a bit.
