I have a 73 340 auto TQ and I couldn't get the air cleaner bolt to go in. Well, took it apart and find out the someone broke off the old stud in the base plate of the TQ. I tried to drill it out but that is getting me nowhere. I just need to pick up another bottom plate. Are the bottom plates pretty much the same through all the years? I also noticed one of the bowls was dry, leaked out through the bottom of one of those little caps on the bottom of the bowls. How hard are they to fix and what to do?
Thanks,
Howard
