Electrical bug Help? #80460
06/27/08 11:04 AM
06/27/08 11:04 AM
Northampton Pa
65 NSS 500 Offline OP
Northampton Pa
I just put a turn signal switch in my 65 Coronet to fix a no brake/turn light problem. I now have turn signal light on consant unless I switch off works on both sides. I have the left brake light but no right. Checked bulb/ground. The turn signal arrow on right of dash dont light is that a concern or it dont matter. Also I want to change the flasher but where is it I cant find it. Maybe why theres no turn flash. Also on the switch from herbs The diagram does not explain what to do with the purple and orange wire from the switch. Or the two off white wires from the dash . Not sure where to go with them yet. I assume the orange is the horn and the purple goes to console for reverse lights? Any pointers of where to go next would be appreciated.
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: Electrical bug Help? [Re: 65 NSS 500] #80461
06/27/08 11:59 AM
06/27/08 11:59 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
turn signal switch has nothing to do with back up lights or the console. Yes there is a flasher.
Re: Electrical bug Help? [Re: stumpy] #80462
06/27/08 01:09 PM
06/27/08 01:09 PM
Northampton Pa
Northampton Pa
Thanks , I know theres a flasher I can seem to find it under the dash. I think it may be out of car but dont see where it goes. It is the 3 prong canister style. Doesnt look like it goes on fuse block or back of dash? Can find where it goes. Any more thought always welcome.
Re: Electrical bug Help? [Re: 65 NSS 500] #80463
06/27/08 02:41 PM
06/27/08 02:41 PM
Andrewh Offline
Andrewh  Offline
Sits just above my ash tray in my 65.
Re: Electrical bug Help? [Re: 65 NSS 500] #80464
06/27/08 03:11 PM
06/27/08 03:11 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Bear in mind that the flasher is simply a very low-capacity circuit breaker. When it heats up from the load of the bulbs, the breaker opens the circuit, cools down from no load, closes the circuit, and the cycle repeats.
This is what makes the lights flash.
Assuming that the wiring is correct, any of the turn signal bulbs coming on is an indication that a flasher [of unknown condition] is present. A missing flasher would cause an open circuit.
Although the lights may not flash [stay on solid] because of a bad flasher, they also won't flash if the circuit does not have enough load (e.g. not enough bulbs lit). Trace the non-working bulb issue (wiring, sockets, bulbs, grounds) before losing sleep over the flasher.
Down to just a blue car now.
