Re: 514 on the dyno
[Re: greendart408]
#804212
02/08/11 09:20 PM
02/08/11 09:20 PM
Posts: 30,992 Oregon
AndyF
This is good news. How much hp and torque is the new dyno stuff good for?? I forgot to ask Paul when I talked to him last..
Should be good for 1500 hp now but we need to verify that. We'll have a temp sensor in the dyno now so we can watch the temp of the water exiting the dyno. The new pump should hold 1500 hp but some of the older plumbing on the pressure side is restrictive so it might not actually handle that much power. That is the next upgrade on the list.
Re: 514 on the dyno
[Re: MRMOPAR622]
#804213
02/08/11 09:21 PM
02/08/11 09:21 PM
AndyF
Andy,with the big bore block wouldn't the 572-13 heads be a better choice? Only a question.
Sure, or B1 heads. But I don't have either of those so I'm running what I have.
Re: 514 on the dyno
[Re: AndyF]
#804214
02/08/11 11:21 PM
02/08/11 11:21 PM
Posts: 761 KY
juicedcuda
KY
What size carb are you running?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: 514 on the dyno
[Re: juicedcuda]
#804216
02/09/11 02:21 AM
02/09/11 02:21 AM
AndyF
It is one of the new Holley Ultra Dominator 1150 carbs. These are nice carbs. All aluminum, external linkage, billet metering blocks with full adjustment, etc. This carb had a nice fuel curve right out of the box.
Re: 514 on the dyno
[Re: AndyF]
#804220
02/17/11 07:00 PM
02/17/11 07:00 PM
Posts: 87 Denmark
Dart of Denmark
Denmark
Well it took a long time but we're ready to start running the 514 again. We had to install a new water pump for the dyno which cost a bunch of money, and then a bunch of the plumbing for the dyno cell had to be redone to handle the additional water flow. We also had to replace the existing load cell on the dyno and upgrade some sensors. So it took several months to fit all that work in around all of the other activity that was going on. But now the new dyno cell is back up and running. The new load cell has been calibrated and has had a few runs on it. So I'll be able to start getting some new numbers for this 514 this week.
Re: 514 on the dyno
[Re: gregsdart]
#804230
02/21/11 06:41 PM
02/21/11 06:41 PM
AndyF
What ring size and type?
Rings came with the pistons from Diamond. It is an 0.043 top ring. I don't recall the details on the rings but they were more "trick" than what I usually run. It was something that Diamond picked for the motor.
