1 and 8 won't fire WHATS GOING ON ????? #80222
06/26/08 06:21 PM
06/26/08 06:21 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
I changed the distributor , wires , plugs , coil, distributor cap, and even checked the cam it did not wipe it. I have petonix and tried points in it. It keeps backfiring through the exhaust and it wont fire on cylinders 1 and 8 all others fire WHAT IS WRONG WITH THIS??? 340
Re: 1 and 8 won't fire WHATS GOING ON ????? [Re: 340Scamp] #80223
06/26/08 06:31 PM
06/26/08 06:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you done a compression check ?
Re: 1 and 8 won't fire WHATS GOING ON ????? [Re: stumpy] #80224
06/26/08 07:19 PM
06/26/08 07:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Wild guess but check your spark plug wire orientation. 1 & 8 are next to each other in the cap. Do you have them switched?
Re: 1 and 8 won't fire WHATS GOING ON ????? [Re: MoparforLife] #80225
06/26/08 09:27 PM
06/26/08 09:27 PM
calif
cupcake Offline
cupcake  Offline
calif
180 out
Re: 1 and 8 won't fire WHATS GOING ON ????? [Re: stumpy] #80226
06/26/08 10:20 PM
06/26/08 10:20 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
I'll try a compression check tomorrow. THANKS!
Re: 1 and 8 won't fire WHATS GOING ON ????? [Re: 340Scamp] #80227
06/27/08 12:16 AM
06/27/08 12:16 AM
md
mopars4ever Offline
mopars4ever  Offline
md
180 out
Huh! It wouldn`t run if it was 180 out. He said it was running but missing/ not firing on 1 and 8. I vote for wires being crossed. Mike
Re: 1 and 8 won't fire WHATS GOING ON ????? [Re: mopars4ever] #80228
06/27/08 07:17 PM
06/27/08 07:17 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
180 out
Me too... Counter-clockwise.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 1 and 8 won't fire WHATS GOING ON ????? [Re: sunroofgtx] #80229
06/27/08 09:03 PM
06/27/08 09:03 PM
Mass
charge70 Offline
charge70  Offline
Mass
When you swapped the points for the pertronics,did you use the same dist.body.I was thinking that possibly the dist.shaft may be slightly bent screwing the dwell on those two cylinders.Just a thought. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 1 and 8 won't fire WHATS GOING ON ????? [Re: charge70] #80230
06/27/08 09:55 PM
06/27/08 09:55 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
If there is too much runout in the shaft on a stock dist they wont trigger.
MM
Re: 1 and 8 won't fire WHATS GOING ON ????? [Re: 500ciDuster] #80231
06/27/08 10:08 PM
06/27/08 10:08 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
I just found out what it was. I have my coil on my inner fender and it has a pretty long coil wire. when I changed the plug wires I did not change the coil wire ( none long enough ) Changed that an set the timing and it sounds crisp now . THANKS to everyone, really appreciate it. Thank GOD! this was driving me nuts.
