an A-body 7 1/4 will have the bbp also,they are small and easy to brake though!
good for a spare in a pinch too
there are some c-body and truck axles that can be cut and resplined to fit the A-body housing,about 65$ at moser + shipping x 2,they just cant neck down in the area that gets cut and splined
new axles from moser are bolt and play...same with DR Diff
and you can have your small stuff redrilled and get by if ya not
it
the moser axles will make it a little wider also cause of the large brake offset on the axle,so measure ya whells good...its like a 1/4 inch each side no biggie
I used 4 1/2" back space on my 7 " rim in a 68 dart with a 245/60/15 tire and fit just right
