Big Block 727 Taranny Fluid Capacity #80195
06/26/08 05:37 PM
06/26/08 05:37 PM
Indiana
Beastiedoggie Offline OP
Indiana
Can anayone tell me the amount in quarts or pints for the bb727?
beast
Re: Big Block 727 Taranny Fluid Capacity [Re: Beastiedoggie] #80196
06/26/08 06:59 PM
06/26/08 06:59 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
that will change depending on what size converter, pan,cooling system somewhere in the 9-11 quart range would be a safe bet
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Big Block 727 Taranny Fluid Capacity [Re: dusturbd340W5] #80197
06/26/08 07:00 PM
06/26/08 07:00 PM
Kissimmee Fl.
Kissimmee Fl.
and that is assuming a completly empty unit after a rebuild and cooler flush
Re: Big Block 727 Taranny Fluid Capacity [Re: dusturbd340W5] #80198
06/26/08 09:32 PM
06/26/08 09:32 PM
Indiana
Indiana
Thank You...got it!!!
Darryl
beast
