Pulley alignment problem #80150
06/26/08 04:09 PM
06/26/08 04:09 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Has anyone ever had a problem with alignment of March pulleys using factory brackets on a 71 Challenger? I used spacers on the crank pulley to align with the alt. and waterpump but there is no way I can use that many spacers for the power steering pump without throwing off the other two. March is being no help what so ever. They asked if there is anyway I can space the power steering pump back to alignment. Well if there were, why would I be calling them? Any help? See pic
Re: Pulley alignment problem [Re: Shatar4] #80151
06/26/08 04:15 PM
06/26/08 04:15 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i think your power steering pulley maybe installed backwards. on the stock one i remember the stub being toward the front so you could use a power steering pump pulley puller to remove it. that should bring it alot closer to alignment.
if all else fails, i make custom hub centric spacers to fix alignment issues.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Pulley alignment problem [Re: Jerry] #80152
06/26/08 04:26 PM
06/26/08 04:26 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Here is a pic from the front of the motor. As far as I can tell, there is only one way it can go on the pump.
Re: Pulley alignment problem [Re: Shatar4] #80153
06/26/08 05:52 PM
06/26/08 05:52 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
The body/shaft on your power steering pump looks really long. Are you running a stock pump? I had a similiar problem on my 360 except I had to shim the pump out to get the March pulleys to line up. I cant remember but did they sell 2 different sets, one for the Federal type pumps and one for the Saginaw type?
Re: Pulley alignment problem [Re: Moonraker] #80154
06/26/08 06:25 PM
06/26/08 06:25 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
This is what I'm using.
Re: Pulley alignment problem [Re: Shatar4] #80155
06/27/08 01:39 PM
06/27/08 01:39 PM
Moonraker Offline
Moonraker  Offline
That body/shaft is defintely different than a stock style pump, that is your problem right there. Go to a local parts store and ask to see a reman. pump for your make/model and you will see the difference.
Re: Pulley alignment problem [Re: Moonraker] #80156
06/27/08 03:39 PM
06/27/08 03:39 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Kinda looks the same except for the chrome.
http://www.autopartswarehouse.com/detail...QQA1206159.html
Re: Pulley alignment problem [Re: Shatar4] #80157
06/27/08 04:08 PM
06/27/08 04:08 PM
Moonraker Offline
Moonraker  Offline
Hmmm... your right they do look similiar. If you flip your brackets holding the pump so the offset is moving the pump back?? Is it possible the brackets are on wrong?? I'm suprised being an E-body there hasnt been more replys to the post. Can someone post a pick of their small block E-body power steering setup??? Hello board members??
Re: Pulley alignment problem [Re: Moonraker] #80158
06/27/08 09:46 PM
06/27/08 09:46 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
i have the march V groove on my 440. its a pain to do, and can loose your sanity. i used magnetic laser levels , and lathed out my own spacers.
the set is made to be fabriated to your pump.
Re: Pulley alignment problem [Re: mark7171] #80159
06/27/08 10:06 PM
06/27/08 10:06 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
pic ee poo
perspective is in line with the alt.
Re: Pulley alignment problem [Re: Shatar4] #80160
06/29/08 01:58 AM
06/29/08 01:58 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
i would lathe or mill it down.
