is 10.08 about right for this combo? #798971
09/11/10 11:33 PM
09/11/10 11:33 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
put 493 in friends 71 duster-3400 lbs w/driver-eng has 98498 ross flat top pistons-approx 86 cc eddy heads,comp 650 roller cam,4.56 gears,14x32's-motor is zero deck-35 degrees timing-think maybe another .10 in combo-what do you think?thanks in advance for looking-rick
Re: is 10.08 about right for this combo? [Re: rbkt65] #798972
09/11/10 11:46 PM
09/11/10 11:46 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
That sounds like pretty good numbers for that weight,depending on the other variables.Intake,carb,header size,etc.
Most flat top piston bigblocks I have tuned like 36-38 dgrees of timing,so you might play with timing.Carb tuning,playing with shift points,etc. might get you where you want to be.
Re: is 10.08 about right for this combo? [Re: Dunnuck Racing] #798973
09/12/10 12:43 AM
09/12/10 12:43 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
What speed did it run??
If you can't handle the truth, you're living a lie.......
Re: is 10.08 about right for this combo? [Re: Big Squeeze] #798974
09/12/10 09:22 PM
09/12/10 09:22 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
60 ft was 139/140,1/8 mile 6.37/107,638/106,1/4 130/131-also w/better air today car ran 9.97 on brakes and also found timing was nor 35 but 30-timing lite quit so borrowed 2 lights and said it was at 30 degrees-did not change timing to 35 because no more time runs-won 1st round and 2nd round dialed 9.97 and ran dead on and lost due to light-may be another .1/.2 in combo though.
Re: is 10.08 about right for this combo? [Re: rbkt65] #798975
09/13/10 09:52 AM
09/13/10 09:52 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
your post is hard to decipher...
but taking a little timming out will help get more mph..sometimes it translates into better et if the shift points hit the spot.
fwiw..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: is 10.08 about right for this combo? [Re: rbkt65] #798976
09/13/10 08:12 PM
09/13/10 08:12 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
looks pretty good to me.
1320/131= 10.07
Wondering about 1/8 mile number.
660/107= 6.16
May be room for improvement in 1st 1/8.
IMO
