can I get a replacement piston for 1965 383 hp #79669
06/25/08 09:34 PM
06/25/08 09:34 PM
NE Oklahoma
71valiant Offline OP
NE Oklahoma
I just need one. the engine is low mileage 1965 OEM std bore HP 383. My buddy burnt a piston. Im gonna try see if I can get him one. Does kb or someone make something similiar? thanks
Re: can I get a replacement piston for 1965 383 hp [Re: 71valiant] #79670
06/26/08 12:57 AM
06/26/08 12:57 AM
Re: can I get a replacement piston for 1965 383 hp #79671
06/26/08 12:59 AM
06/26/08 12:59 AM
Re: can I get a replacement piston for 1965 383 hp [Re: 71valiant] #79672
06/26/08 12:59 AM
06/26/08 12:59 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Keep in mind the inbalance problem you will have with changing out one piston with a new one of a different kind. (suppose only an NOS original one might be close?)
Re: can I get a replacement piston for 1965 383 hp [Re: OzHemi] #79673
06/26/08 01:01 AM
06/26/08 01:01 AM
Well he should go with cast to be close, maybe search Ebay or craigslist for a used one.
Here's a cool multi area craigslist searcher.
http://www.craigshelper.com/
Re: can I get a replacement piston for 1965 383 hp #79674
06/26/08 01:54 AM
06/26/08 01:54 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Well since the sealed power one are made to be OEM replacements, I think they make them close enough in weight to work with the factory balance. And we all know how poor the factory balance is, so just buy a single sealed power piston from summit and forget about it.
Re: can I get a replacement piston for 1965 383 hp [Re: DaytonaTurbo] #79675
06/26/08 06:46 PM
06/26/08 06:46 PM
NE Oklahoma
NE Oklahoma
I'm just wondering about piston height. I dont know if the pistons for a non hp 383 are the same as they are for a HP 383.
Re: can I get a replacement piston for 1965 383 hp [Re: 71valiant] #79676
06/26/08 11:53 PM
06/26/08 11:53 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
The best way of going about this is to remove the burnt piston, measure the c.d., then find who sells one with a similiar c.d. If you get lucky enough to find one then weight match it with one of the old pistons. Without measuring and weighing the old piston first you are just guessing.
Randy
Re: can I get a replacement piston for 1965 383 hp [Re: 71valiant] #79677
06/27/08 07:24 AM
06/27/08 07:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
depending on the year a non HP may have a dish .
good luck finding a replacement , i have not see ANY replacement piston for a 383 that is the same height as the factory installed piston
Re: can I get a replacement piston for 1965 383 hp [Re: JohnRR] #79678
06/27/08 08:21 AM
06/27/08 08:21 AM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
i have 4 383hp flattop pistons I could let one go they are about 1/8 in higher then non hp. BUT mine came off a 68-69 383hp. I live in kearney NE come pick it up if you want 20 bucks.
Re: can I get a replacement piston for 1965 383 hp [Re: ngpSatellite] #79679
06/27/08 08:51 AM
06/27/08 08:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thats a taller CH piston than a 65
