Need 340 valve lash specs #79528
06/25/08 02:28 PM
06/25/08 02:28 PM
S Williamsport
therick Offline OP
therick  Offline OP
S Williamsport
I need to know what the valve lash is on a stock 340 t/a. I need to adjust the valves tonight (Wednesday. All help is appriciated. Thanks Rick
Re: Need 340 valve lash specs [Re: therick] #79529
06/25/08 04:08 PM
06/25/08 04:08 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
a stock 340 6 pak has a hydraulic cam and therefore has no lash..
the lifters are preloaded.....
Tony
70 AARCuda Vitamin C
Re: Need 340 valve lash specs [Re: 70AARcuda] #79530
06/25/08 04:29 PM
06/25/08 04:29 PM
S Williamsport
therick Offline OP
therick  Offline OP
S Williamsport
This has a solid cam in it. Was told i is stock.
Re: Need 340 valve lash specs [Re: therick] #79531
06/25/08 04:32 PM
06/25/08 04:32 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
they come with adjustable rockers but the stock cam was hydraulic...
if it is a solid cam then someone change it out...you will need to find out what cam is in it to find the lash for that cam.
Tony
