Plug wires? - just switched from headers to manifolds #79514
06/25/08 01:40 PM
06/25/08 01:40 PM
White Plains NY
VitaminCRunner Offline OP
White Plains NY
Does anyone know what spark plug boot is needed for manifolds, my old headers had some 90" and some straight.
Any wires have a stock look?
thanks -
Re: Plug wires? - just switched from headers to manifolds [Re: VitaminCRunner] #79515
06/25/08 01:52 PM
06/25/08 01:52 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I don`t have any pics but I just bought a set of fyrewires<sp? from a fellow board member. They have the correct boot ends on them and are a good product. The are way above the resto date coded wires that are out there.
Re: Plug wires? - just switched from headers to manifolds [Re: badblack68] #79516
06/25/08 08:11 PM
06/25/08 08:11 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Yes, shoot sunroofgtx{Rick} a PM and he'll fix you up with a great looking and performing set of wires just tell him what you're looking for....They're called firecore wires now...Very low resistance per foot... He has stock appearing wires or sets with heatshields for those close header clearances...
Re: Plug wires? - just switched from headers to manifolds [Re: VitaminCRunner] #79517
06/25/08 09:19 PM
06/25/08 09:19 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
me,personally, I prefer what ma mopar intended
Re: Plug wires? - just switched from headers to manifolds [Re: gtx6970] #79518
06/26/08 05:10 PM
06/26/08 05:10 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Here is a nice comparison. These are exact fit.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Plug wires? - just switched from headers to manifolds [Re: sunroofgtx] #79519
06/26/08 05:38 PM
06/26/08 05:38 PM
I see all 90* boots.Is that correct?
Re: Plug wires? - just switched from headers to manifolds #79520
06/26/08 07:12 PM
06/26/08 07:12 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Well, to be technical, the number 8 should be a 135. We can make it exact, but usually most customers don't care. The 8 is under and know one usually can see unlees looking specifically. We actually, to make it exact, take a small block 180, and bend the variangle terminal. It looks so perfect, it would pass as OEM. But we are not in the OEM business. Too many variables. We make performance ignition wires that happen to look stock.
