Page 4 of 5 1 2 3 4 5
Re: The weekend lowering project [Re: 76dodgeboy] #795184
09/21/10 09:00 PM
09/21/10 09:00 PM
South Carolina
Jere Offline
Jere  Offline
South Carolina
I follow now. Sorry just a little slow on your thinking. I was told that a 3" drop on a 94 would equal a 2" drop on a 93. I guess I would be better off taking off the 94 springs and cutting 1 coil on my old springs for a 2" drop for now so I don't have to deal with the steering and the ball joint angle right now.
Re: The weekend lowering project [Re: Jere] #795185
09/22/10 02:09 AM
09/22/10 02:09 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Thats the case if it didnt have the pocketed control arms. I plan to use 94 up drop coils in one of my trucks aswell. Want to sell yours? I have more than 1 truck I have a set of stock 1/2 ton coils you can have to see where itll sit than you can buy new or use them
Re: The weekend lowering project [Re: adventurer] #795186
09/22/10 01:55 PM
09/22/10 01:55 PM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
I went to Pull-A-Part here in Nashville today. It appears that ALL vans have the same lower control arm. I looked at two half ton vans and the lower control arms looked the same as the ones in the 3/4 ton and ton vans. Does this sound right?
I also wasn't able to break lower control arm loose from the steering knuckle in the junkyard. I asked if they could do it for a fee and they won't. Maybe I can find some loose somewhere. Do any of you guys have a pair for sale?
Re: The weekend lowering project [Re: Kevin I] #795187
09/22/10 02:31 PM
09/22/10 02:31 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
From what Ive seen at the jy I would agree but you best bet is go to rockauto.com and compare balljoints and control arm bushings. I believe 1 ton vans have a bigger bj for sure. I believe another member awhile back posted pics of what he had and it was bigger
Re: The weekend lowering project [Re: 76dodgeboy] #795188
09/22/10 09:26 PM
09/22/10 09:26 PM
South Carolina
Jere Offline
Jere  Offline
South Carolina
Half ton springs won't work for me cause I am a diesel. But I may sell them. Do you think 1 coil cut off will drop the front 2 in.
Re: The weekend lowering project [Re: Kevin I] #795189
09/23/10 01:17 AM
09/23/10 01:17 AM
It's beer:30 somewhere
adventurer Offline OP
Kevin on breaking the arm loose from the knuckle I couldn't on mine either, I took out the two bolts that hold the lower part of the knuckle to the upper part, if my memory is right it takes a 15/16" socket and wrench to get these loose, this is the part that the lower ball joint goes through and just bought them that way. Then when I got them home I was able to seperate the ball joint from that lower part of the knuckle. As far as I know on your question about 1/2 ton vans. I'm pretty sure as long as they have the spring pocket in the arm they are the same. Hope this helps you. See ya at the Music City show.
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: The weekend lowering project [Re: Jere] #795190
09/23/10 01:55 AM
09/23/10 01:55 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You could try 1 and see where it sits and if need be remove a 1/2 at a time after that. I took 1.5 coils out on my 73 Clubcab and it road on the bumpstop brackets. Id give it a shot. Nothing to loose
Re: The weekend lowering project [Re: adventurer] #795191
09/23/10 09:20 AM
09/23/10 09:20 AM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
Thanks for the tip. I was kinda frustrated yesterday. I didn't have much time to do it (lunch break) and some goober started taking something off the rear axle when I was tugging on it. I was afraid I'd knock the van off the wheels they had it propped up on and crush the guy, so I left.
I gotta put some tires on my wife's Durango Saturday morning. After that, I'm heading to Lebanon for the Mopar show. I'll see you there.
Re: The weekend lowering project [Re: 76dodgeboy] #795192
10/03/10 09:27 PM
10/03/10 09:27 PM
South Carolina
Jere Offline
Jere  Offline
South Carolina
It doesnt ride lower. Half and 3/4 tons use a coil that is 11" tall when on the ground and yours are 13.13" when on the ground installed on the truck so its actually only .13" taller do to the pocket. Free hieght for the stock 94 coils are 12.92dr and 12.63ps and thats not loaded. so take 3" out of than and its 9" for both plus 2"for the coil totaling 5" of drop. Did you put the springs side by side?
Ok so I removed the '94 dodge 3500 springs from my 93 dodge d350. I don't think that the company sent me the right springs. They are the same length but the coil thickness is alot thinner. The ammount of winding are the same too. This would explain why everything is so low in the front.
Re: The weekend lowering project [Re: adventurer] #795193
10/15/10 07:40 PM
10/15/10 07:40 PM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
You were right. They were 15/16". It was so easy knowing that. The hardest part was getting that nut off the top of the shock. Now, I gotta clean them up and paint them. I can't decide if I will lower the rear with the flipped hangers/longer shackles or flip the axle on top of the leafs. I will probably lower the front and see what I have there and decide then.
Re: The weekend lowering project [Re: Kevin I] #795194
10/15/10 09:49 PM
10/15/10 09:49 PM
Yeah that makes it a lot easier by taking those bolts out. On the axle on top of the springs I personally have not done it but my understanding is that you ended up with about a 4 1/2" to 5" drop which I kind of think is to much for my tatse but to each their own. Good luck with it Kevin. Keep us posted.
Larry
14 Ram R/T
Re: The weekend lowering project [Re: adventurer] #795195
01/22/11 01:08 PM
01/22/11 01:08 PM
Springfield, Ohio
shortbed88 Offline
shortbed88  Offline
Springfield, Ohio
Sorry to drag up an old post, but thought this question might be better answered here. I have van pocketed arms and new Trw 3/4 ton springs in the garage waiting for warmer weather. I had planned on trimming the 3/4 ton springs before I put them in, but I can't decide how much. My truck also has a horrible case of the dodge lean. I have almost 1 inch on lean to the driver side. So should I cut one round off the new springs, or would it be better to stagger them say, one full round drive side and a half round passenger. Or should the new springs solve the lean. I would like to get this truck low. In the range of the mid america kit. I am seriously considering a spring over in the rear since I am changing the rearend. I have an 3.55 limited slip rearend sitting in the "truck parts pile".
Thanks for the help.
1988 Dodge D100 Short bed
Re: The weekend lowering project [Re: shortbed88] #795196
01/22/11 01:26 PM
01/22/11 01:26 PM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
i'm not sure about the 3/4 ton springs but I cut 1/2 coil on each(I had no lean)and used my stock coils (/6) and the van control arms (and flipped the back I run 235 70 15 on the front and 255 70 15 on the rear
Get Real Get Mopar
Re: The weekend lowering project [Re: 1moparman] #795197
01/22/11 01:38 PM
01/22/11 01:38 PM
Springfield, Ohio
shortbed88 Offline
shortbed88  Offline
Springfield, Ohio
Thanks 1moparman, That is the look I am going for. I may try trimming up my stock springs before I cut up the new ones. Maybe I can trim the passenger side to compensate for the lean.
Re: The weekend lowering project [Re: 1moparman] #795198
01/22/11 01:40 PM
01/22/11 01:40 PM
Clinton Twp. Michigan
coronet1966d Offline
from what i could tell at the parts store the /6 and small block springs are the same, my truck with /6 springs and a big block is way too soft in the front. im planning on trying stock height 3/4 ton springs
if i were you id install the 3/4 springs at stock height and check if that corrects your lean issue. then remove and trim as you see fit
Re: The weekend lowering project [Re: coronet1966d] #795199
01/22/11 03:35 PM
01/22/11 03:35 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
3/4 ton and half ton share the same front coils unless heavy duty. The heavy duty ones are basically one ton and are taller than 3/4&1/2 tons and are what is used with the Pocketed control arms.
Re: The weekend lowering project [Re: 76dodgeboy] #795200
01/22/11 03:40 PM
01/22/11 03:40 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Rockauto.com
1/2 ton
1990 DODGE D150 PICKUP 5.2L 318cid V8 TBI (Y) OHV : Suspension : Coil Spring Wiki Price
RAYBESTOS Part # 5851080 Professional Grade; Sold in Pairs -- Inside Diameter=4" Wire Diameter=.812" Free Height=12.6" Load height=10.5"
Front
$73.79
Add to Cart
MOOG Part # 7170 Sold In Pairs
Frt Susp; Standard Duty Replacement; Constant Rate Springs
$76.79
Add to Cart
RAYBESTOS Part # 5851081 Professional Grade; Sold in Pairs -- Inside Diameter=4" Wire Diameter=.820" Free Height=12.5" Load height=11"
Front; Heavy Duty
$81.79
Add to Cart
ROCKWELL Part # RC7170 Sold In Pairs
Front; w/ AC; w/ M/T; Pickup
Front; w/ AC; w/ A/T; Pickup
Front; w/o AC; w/A/T; Pickup
Front; w/o AC; w/M/T; Pickup (Only 1 Remaining)
$81.79
Add to Cart
ROCKWELL Part # RC7172 Sold In Pairs
Front; w/o AC; w/A/T; Heavy Duty; Pickup
Front; w/ AC; w/ A/T; Heavy Duty; Super Duty; Pickup
Front; w/o AC; w/M/T; Heavy Duty; Pickup
Front; w/ AC; w/ M/T; Heavy Duty; Pickup
Front; w/ AC; w/ M/T; Heavy Duty; Super Duty; Pickup
Front; w/o AC; w/M/T; Heavy Duty; Super Duty; Pickup
Front; w/ AC; w/ A/T; Heavy Duty; Pickup
Front; w/o AC; w/A/T; Heavy Duty; Super Duty; Pickup (Only 2 Remaining)
$81.79
Add to Cart
MOOG Part # 7172 Sold In Pairs
Frt Susp; Heavy Duty Replacement; Constant Rate Springs
$82.99
Add to Cart
RAYBESTOS Part # 5851212 Professional Grade; Sold in Pairs -- Inside Diameter=4" Wire Diameter=.828" Free Height=13.02" Load height=11"
Front; Severe Duty
$88.79
Add to Cart
MOOG Part # 7172S Sold In Pairs
Frt Susp; Severe Duty Replacement; Constant Rate Springs
$91.89
Add to Cart
3/4 ton
1990 DODGE D250 PICKUP 5.2L 318cid V8 TBI (Y) OHV : Suspension : Coil Spring Wiki Price
Front; Except 4000 Lb Axle
$73.79
Add to Cart
Frt Susp; Exc. IFS-4000; Constant Rate Springs
$76.79
Add to Cart
Front; Except 4000 Lb Axle; Heavy Duty
$81.79
Add to Cart
Front; w/ AC; w/ M/T; Heavy Duty; Super Duty; Exc. IFS-4000
Front; w/ AC; w/ A/T; Heavy Duty; Exc. IFS-4000
Front; w/ AC; w/ M/T; Heavy Duty; Exc. IFS-4000
Front; w/ AC; w/ A/T; Heavy Duty; Super Duty; Exc. IFS-4000
Front; w/o AC; w/A/T; Heavy Duty; Super Duty; Exc. IFS-4000
Front; w/o AC; w/M/T; Heavy Duty; Super Duty; Exc. IFS-4000
Front; w/o AC; w/A/T; Heavy Duty; Exc. IFS-4000
Front; w/o AC; w/M/T; Heavy Duty; Exc. IFS-4000 (Only 2 Remaining)
$81.79
Add to Cart
Front; w/o AC; w/A/T; Exc. IFS-4000
Front; w/ AC; w/ A/T; Exc. IFS-4000
Front; w/o AC; w/M/T; Exc. IFS-4000
Front; w/ AC; w/ M/T; Exc. IFS-4000 (Only 1 Remaining)
$81.79
Add to Cart
Frt Susp; Exc. IFS-4000; Heavy Duty Replacement; Constant Rate Springs
$82.99
Add to Cart
Front; Except 4000 Lb Axle; Severe Duty
$88.79
Add to Cart
Frt Susp; Exc. IFS-4000; Super Duty Replacement; Constant Rate Springs
$91.89
Add to Cart
ROCKWELL Part # RC7226 Sold In Pairs
Front; w/ AC; w/ M/T; Heavy Duty; Super Duty; w/ IFS-4000
Front; w/ AC; w/ A/T; Heavy Duty; w/ IFS-4000
Front; w/o AC; w/M/T; Heavy Duty; w/ IFS-4000
Front; w/ AC; w/ M/T; Heavy Duty; w/ IFS-4000
Front; w/o AC; w/A/T; Heavy Duty; Super Duty; w/ IFS-4000
Front; w/ AC; w/ A/T; Heavy Duty; Super Duty; w/ IFS-4000
Front; w/o AC; w/M/T; Heavy Duty; Super Duty; w/ IFS-4000
Front; w/o AC; w/A/T; Heavy Duty; w/ IFS-4000 (Only 2 Remaining)
$107.79
Add to Cart
RAYBESTOS Part # 5851108 Professional Grade; Sold in Pairs -- Inside Diameter=3.99" Wire Diameter=.906" Free Height=14.65" Load height=13.13"
Front; 4000 Lb Axle; Heavy Duty
$108.79
Add to Cart
MOOG Part # 7226 Sold In Pairs
Frt Susp; w/IFS-4000; Heavy Duty Replacement; Constant Rate Springs
$113.79
Add to Cart
RAYBESTOS Part # 5851213 Professional Grade; Sold in Pairs -- Inside Diameter=4" Wire Diameter=.906" Free Height=15.1" Load height=13.13"
Front; 4000 Lb Axle; Severe Duty
$126.79
Add to Cart
MOOG Part # 7226S Sold In Pairs
Frt Susp; w/IFS-4000; Super Duty Replacement; Constant Rate Springs
$130.79
Add to Cart
ROCKWELL Part # TT7215 Sold In Pairs
Front; HD Upgrade; 3500lb Rating; 3" Lift Over New Stock Height; 2WD (Only 2 Remaining)
$282.79
Add to Cart
1ton
Re: The weekend lowering project [Re: adventurer] #795201
03/11/11 08:55 PM
03/11/11 08:55 PM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
I finally got my arms painted. I started on lowering the front last Sat. but smashing my fingers (bled through my left ring finger nail) while loosening the pivot bolt and trouble locating a 3/4" drill bit has held me up. I fooled with it a little today after work. The holes in my driver's side control arm didn't line up with the ones on the pivot bracket. I found that the metal around the pivot bushing was up against the pivot bracket. I had to grind off a little metal around the top on both sides to leave some room for the arm to move.
I had to drive around to find a 3/4" drill bit. I finally ended up buying one of those unibits. I had to drill the front and back for both holes to get it right because the steps aren't wide enough on the unibit.
Re: The weekend lowering project [Re: adventurer] #795202
03/24/11 09:10 PM
03/24/11 09:10 PM
CANADA B.C.
PROPANEPOWER Offline
CANADA B.C.
what year lca's are you guys using for lowering the trucks are all the dodge van lca's the same?
Re: The weekend lowering project [Re: PROPANEPOWER] #795203
03/24/11 10:36 PM
03/24/11 10:36 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yes the van control arms are the same up to 97 I believe but the 1 tons take a big balljoint and you'll have to ream out your spindle for the bigger balljoint IIRC correctly. You can go to rockauto.com and search the yrs to see when they changed and the diff bj's
