Page 2 of 3 1 2 3
Re: problems with 604" predator motor [Re: B G Racing] #794809
09/07/10 01:06 PM
09/07/10 01:06 PM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
As I recall your original engine builder overfilled the block with hard block. The engine has oil pressure on start up but since it does not circulate water with a traditional water pump (block overfilled) the oil gets hot after idleing for 10-15 minutes and looses it viscosity. I believe I suguested you could circulate water thru the heads and run the engine for short periods of time. Or get a new block (that is not overfilled)
Mike @ MM
Re: problems with 604" predator motor [Re: MuscleMike] #794810
09/07/10 01:39 PM
09/07/10 01:39 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
Mike @ MM
see! i knew muscle motors was too good not to find a problem
Re: problems with 604" predator motor [Re: tjmarcus1] #794811
09/07/10 04:21 PM
09/07/10 04:21 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
A local racers filled his CBB with hard block to high also, so it blocked all the channels between the cylinders.
He manage to remove enough of the concrete with drilling and using a hammer, it was a lot of work but he saved the block.
He discovered his mistake just after it was filled and already hard, but before he put the engine together.
I would give it a try before I bought a new block.
Re: problems with 604" predator motor [Re: RT540] #794812
09/07/10 04:23 PM
09/07/10 04:23 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I thought there was muratic acid or whatever could eat that stuff out ...
Mopar Performance
Re: problems with 604" predator motor [Re: tjmarcus1] #794813
09/07/10 04:27 PM
09/07/10 04:27 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
You cant diagnose the problem over the Internet with out a detailed parts list.
What lifter and how much lump on the camshaft.To much lift you might be windowing the lifter skirt to the oil (you should be safe to .470 with most lifters)
When you dropped the engine off did you give them permission to completely disassemble and rebuild the engine ?
Try a different pump ?
Cranking the pump by hand you should see 40 to 50 psi if not the oil should be hosing out from somewhere.
you should only see about a 10 psi drop from cold to hot.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: problems with 604" predator motor [Re: MuscleMike] #794814
09/07/10 04:36 PM
09/07/10 04:36 PM
go green Offline
go green  Offline
Mike @ MM
I cant see this being the problem but putting a temp gauge would settle the argument.
Re: problems with 604" predator motor [Re: MuscleMike] #794815
09/07/10 05:07 PM
09/07/10 05:07 PM
Hartford,MI
goody340g Offline OP
Hartford,MI
Mike @ MM
mike talked to dad today and he did say that is what u guys came up with. i don't remember hearing anything about that at the time but i was just half a** helping them anyways. i apoligize if it sounded like i was knocking mm, that was not my intention, i know it is a pain to try a figure out somebody elses mess. i was just trying to pick some brains
Re: problems with 604" predator motor [Re: goody340g] #794816
09/07/10 05:56 PM
09/07/10 05:56 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
here is the most simple test, have you tryed priming it with the same gauge every time?
sometimes its as easy as a faulty sender and or faulty gauge
simplest cheapest and easiest test known to man and have corrected many troubles
Re: problems with 604" predator motor [Re: go green] #794817
09/07/10 06:20 PM
09/07/10 06:20 PM
Hartford,MI
Hartford,MI
i'll have to look up the specs on the cam, we tried many diff. pumps and gauges. so hopefully next week i'll have time to get it on a stand and prime it to see what the press. is cold
Re: problems with 604" predator motor [Re: goody340g] #794818
09/07/10 06:21 PM
09/07/10 06:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
really what does it matter? you already know what the problem is
Re: problems with 604" predator motor [Re: Quicktree] #794819
09/07/10 06:44 PM
09/07/10 06:44 PM
Iowa
coronetville Offline
Iowa
better throw it out. luckly I can give you fair scrap money.......and I can pick it up too!!
Re: problems with 604" predator motor [Re: Quicktree] #794820
09/07/10 08:20 PM
09/07/10 08:20 PM
Hartford,MI
Hartford,MI
if you r giving new blocks away it doesn't matter, until then we'll exhaust all options
Re: problems with 604" predator motor [Re: goody340g] #794821
09/07/10 08:41 PM
09/07/10 08:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I r not giving any blocks away but somebody paid good money to figure out the problem, guess you are smarter than the guys at MM
Re: problems with 604" predator motor [Re: Quicktree] #794822
09/07/10 09:18 PM
09/07/10 09:18 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Goodson....what the hell are you doin taken that motor to Rutgers..... Hows Ernie and your Dad doing...been a while since I have seen you guys, are you going to Norwalk for the Classic? I see Jacobs is running the points...hit me up
Re: problems with 604" predator motor [Re: joshking440] #794823
09/07/10 09:19 PM
09/07/10 09:19 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Since your scratchin your head on who this is, here is my dads car...
Re: problems with 604" predator motor [Re: Quicktree] #794824
09/07/10 09:21 PM
09/07/10 09:21 PM
go green Offline
go green  Offline
Its not the oil viscosity .
Oil weight, or viscosity, refers to how thick or thin the oil is. The temperature requirements set for oil by the Society of Automotive Engineers (SAE) is 0 degrees F (low) and 210 degrees F (high). The oil will be stable to the high limit operating zone .Are you suggesting the oil is far exceeding 300 to 400 F ?
Re: problems with 604" predator motor [Re: go green] #794825
09/07/10 09:52 PM
09/07/10 09:52 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
A lot more info needs to be provide to conclude or asertain the possible causes.How is the oil pressure on cold startup,how long before the oil pressure drops,what is engine temperture,oil temperture,and what is the cause of the heat? As mentioned is the filled block the issue?What do the bearings look like?A lot of guess work can be avoided by check the above mentioned issues.Oil passage cracks,plugged or restrictions as well as cooling issues can cause similar issues.We have seen one bad main cap,a crack in the block main bore at the oil passage as well the issues at the lifter bores cause the loss of oil pressure.An easy analysis of the fluid tempertures(which get hot first)would be a good start.Check and recheck all oil pickups,pumps,filters.lines and passages.Check and recheck all cooling systems and passages also.We
find many issues are caused by simple over looked things.
Re: problems with 604" predator motor [Re: go green] #794826
09/07/10 09:57 PM
09/07/10 09:57 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
If it was my engine, I would add a few things and run it...What are you going to do junk the block?
I would add a oil cooler, probably get the whole thing cheap if you look around.
Next I would add alky injection, via Rons Terminator. Its the ultimate in hp over any carb setup. First hand experience says you will pickup substantial e/t with this
I assume you already have a sheet metal intake so this would be easy.
Make the best with what ya got.
The alky will take care of any cooling issues you have. Then the oil cooler will take care of oil temp issue's.
Re: problems with 604" predator motor [Re: Bob_Coomer] #794827
09/07/10 10:16 PM
09/07/10 10:16 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
maybe its something dumb like the oil line is clogged up some to the gauge giving false reading...
Mopar Performance
Re: problems with 604" predator motor [Re: moparniac] #794828
09/07/10 11:08 PM
09/07/10 11:08 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
Sounds like a cavitation problem , or a possible problem with the oil psi relief....
Page 2 of 3 1 2 3
