Re: Heads for a stroker
[Re: 72greencuda]
#79424
06/25/08 08:45 AM
06/25/08 08:45 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
well, you need a big enough cam with a late enough intake closing point to keep "dynamic compression" below 8:1. your stock 72ish cc heads will drop compression down into the 10's...or closed chambered aluminum heads (i.e. eddies, indy) w/tight quench can run on pump gas in the 11.5:1 comp ratio range with the right cam selection
another option, water inject it to control detonation. you could run a lower octane and/or a smaller cam then and have your "dynamic compression" higher, and you might actually see an improvement in fuel economy.
[Re: patrick]
#79425
06/25/08 09:16 AM
06/25/08 09:16 AM
quick77rt
Parts Problem
Parts Problem
My pump gas stroker has the eddy heads. -16 dish pistons, static is 10.6 dynamic is 8.2 and my quench is .035 and its a very good combo. Even dish pistons need good quench were it counts the most. Its obvious patrick is very smart, I could of went higher on my static with the al heads but this combo seems to work so well. Here are two links that might help you understand things a bit better. Even though the second one is from a poncho site its pretty close, just fill it in with the right numbers. Just remember strokers will eat duration like crazy, pic the right cam. http://www.empirenet.com/pkelley2/DynamicCR.html http://www.projectpontiac.com/ppsite/content/view/16/30/
[Re: 72greencuda]
#79426
06/25/08 09:41 AM
06/25/08 09:41 AM
Posts: 1,061 New Mexico
dmerc
New Mexico
You might as well take the plunge and get some Edelbrock heads. Zero deck the block and select a cam that will get you in the 8.2 to 8.5 dynamic effective compression range. It's all in the cam selection. If you want an engine that makes more low end power go with dished pistons and select the cam accordingly. That is what I used and am very happy with my Magnum headed engine. No need for a high stall converter either.
