Re: Coolant Recovery Tank
[Re: Exit1965]
#79057
06/24/08 09:33 AM
06/24/08 09:33 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Another thing or 2 - Don't over fill the system, the coolant should just come up to the baffle plate below the filler neck or about 3/4 inch down. Another is liquid on the floor looks a lot more than it is.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#79059
06/24/08 09:56 AM
06/24/08 09:56 AM
Posts: 2,592 None
71rm23
None
Yoou experience exactly the reason recovery tanks were instituted. It is called heat soak and pressure build up. Without the coolant moving and the engine heat after shut down saturated the coolant in the engine to the boiling point and built pressure, releasing the pressure cap and allowing coolant out on the ground. A recovery tank of any kind would solve this and the use of the proper cap would allow the coolant to return to the radiator after cool down. The recovery hose has to go to the bottom of the tank so that the end is in the bottom of the recovery tank and able to syphone teh coolant.
[Re: 71rm23]
#79060
06/24/08 05:29 PM
06/24/08 05:29 PM
Posts: 6,516 Santa Cruz, California
Lefty
You experience exactly the reason recovery tanks were instituted. It is called heat soak and pressure build up. Without the coolant moving and the engine heat after shut down saturated the coolant in the engine to the boiling point and built pressure, releasing the pressure cap and allowing coolant out on the ground. A recovery tank of any kind would solve this and the use of the proper cap would allow the coolant to return to the radiator after cool down. The recovery hose has to go to the bottom of the tank so that the end is in the bottom of the recovery tank and able to syphone teh coolant.
[Re: RaiderLefty]
#79062
06/24/08 08:51 PM
06/24/08 08:51 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
I tossed a simple white Jazz catch can in mine, not a recovery system though. There are some really neat aluminum ones on the market, I remember someone made a 5-sided one that was awesome - they can cost though. Every car should have some sort of catch system minimally.
Ride eternal, shiny and chrome
[Re: gamagoat6x6]
#79065
06/24/08 10:48 PM
06/24/08 10:48 PM
Andrewh
68 fury came with a round one. Bolted up on the passenger side next to the rad. Works in my 65 coronet.
No `68 fury ever came with one. That`s aftermarket.
Really? Looked like it belonged to me. The bracket and everything looked correct. Even yellowed like the washer bottle. Ah well. It works.
