front wheel drive transmission #79031
06/24/08 04:32 AM
06/24/08 04:32 AM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
can anyone tell me what for transmission they used in a 90 dodge daytona? thanks Brad
Re: front wheel drive transmission [Re: roadrunnerreds] #79032
06/24/08 10:40 AM
06/24/08 10:40 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Auto or manual? What engine?
Re: front wheel drive transmission [Re: Jim_Lusk] #79033
06/24/08 01:58 PM
06/24/08 01:58 PM
Gettysburg Pa
Gettysburg Pa
it has a 2.5 engine with automatic with a lockup converter. Brad
Re: front wheel drive transmission [Re: roadrunnerreds] #79034
06/24/08 02:51 PM
06/24/08 02:51 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
A413. Turbo auto's also used the A413, however they had more clutches and did not have provisions to use a lockup torq converter.
Re: front wheel drive transmission [Re: DaytonaTurbo] #79035
06/25/08 01:53 PM
06/25/08 01:53 PM
Gettysburg Pa
Gettysburg Pa
do you know if there are many differences between an 87 a413 and a 90 a413? i have a 87 trany that if i need any parts i could take them from it? thanks alot Brad
Re: front wheel drive transmission [Re: roadrunnerreds] #79036
06/25/08 04:32 PM
06/25/08 04:32 PM
Manitoba, Canada
Manitoba, Canada
87 will be the same as your 90. Only slightly different if you're mixing turbo with non-turbo.
Re: front wheel drive transmission [Re: DaytonaTurbo] #79037
07/02/08 04:17 PM
07/02/08 04:17 PM
Gettysburg Pa
Gettysburg Pa
Has anyone ever replaced a torque converter in a 413 trany and got one without the mark for setting the timing? i picked one up earlier today for my wifes 90 daytona and it does not have a mark for setting the ignition timing. Brad
Re: front wheel drive transmission [Re: roadrunnerreds] #79038
07/02/08 05:01 PM
07/02/08 05:01 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I had a Shadow and the new transmission/convertor had no TDC mark.
Since it was not a race engine, just a commuter.
Also the engine really only needs you to set the ignition timing as reference. I didn't feel accuracy was that important.
I did the backyard method of looking for TDC feeling for the piston coming up. Made a mark with a paint marker. Did it again on the other side. In between my marks was TDC or close enough.
