It's been a long road but got the car fired up tonight. Today I finnished the trans cooler lines and installed them, filled the trans ,installed the T stat,(put a heli coil in the water pump housing) filled the cooling system and checked for leaks ,wired the fuel pump , wired the cooling fan ,finnished the fuel line from the regulator to the carbs, added fuel to the cell and turned the key. It lit right off and sounds good, but... the front carb flooded. put a new oring on the needle/seat. then the rad had a crack in the top tank. Sodered that. Its still over charging, changed the voltage reg, better but still over charges when it's reved up a little. Got a small leak from the trans dip stick tube. Time to go home tomarrows another day. It WILL be ready for a shake down run by sunday at island dragway. Keep your fingers crossed.
