440 Source Water Pump #78909
06/23/08 09:34 PM
06/23/08 09:34 PM
Nanuet, NY
3
383BeepBeep Offline OP
Nanuet, NY
I put a 440 source w/p in the Bird when I built the engine. Does anyone no what kind of pump it is...standard flow/high volume/high flow/junk? It seems to work fine.
1969 Plymouth Roadrunner - 383- 4 Speed - Dana 60 4:10
Re: 440 Source Water Pump [Re: 383BeepBeep] #78910
06/24/08 02:56 AM
06/24/08 02:56 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Its a hi-flow. I like that impeller design the best. I have a nippon milodon 6 blade waterwheel that I had to spot weld on the shaft because it was loose. Its a backup, dust collector now.
Re: 440 Source Water Pump [Re: earlybee] #78911
06/24/08 07:59 PM
06/24/08 07:59 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Sorry to hi-jack, but lets expand.... How much cooling help can you expect from a high-flow pump over a stock replacement pump?
