440 cam difference #78615
06/22/08 10:32 PM
06/22/08 10:32 PM
Anonymous OP
Anonymous OP
I noticed that Summit lists the thier 440 cam will not fit a 1966/67 440. What was different in the 66/67 cam? I have a 440 built by someone else and the hydrolic lifter is compessed .150 inch off lobe (seems way too much). I'm used to chevys where we would expect about .030 inch colapse in the lifter. What would I do if a correction was needed to the push rod? Mike
Re: 440 cam difference #78616
06/22/08 11:46 PM
06/22/08 11:46 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The 66-67 440's used a pushrod with a different tip. All other 440's used the usual rounded tip, but the 66-67's used a pushrod with a tip that tapers narrower before comming to a point. They also used different lifters for those pushrods. To use any aftermarket cam in a 66-67 440 you must change to the newer style pushrods, summit sells some cheapies.
Re: 440 cam difference [Re: DaytonaTurbo] #78617
06/22/08 11:48 PM
06/22/08 11:48 PM
Manitoba, Canada
Manitoba, Canada
Scroll down to the bottom of this page, brandon has pics of both style pushrods. The 66-67 uses a longer pushrod than 68+, you don't want to try using longer/early pushrods with later style lifters, which is what all aftermarket cam kits come with.
http://www.440source.com/pushrods.htm
Re: 440 cam difference [Re: DaytonaTurbo] #78618
06/23/08 08:59 AM
06/23/08 08:59 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah the 66-67' used tappered push rods. It will work just order a set of Summits push rods and you'll be fine.
