b-body 833
#785214
08/26/10 11:41 PM
08/26/10 11:41 PM
Posts: 905 SD
zrxkawboy
SD
I'm going to start looking for an 833 for my '67 Belvedere (it currently has 3-on-the-tree). Am I correct in thinking that any b/e-body trans will work, or will only certain years fit? Thanks!
It's Swifty! Swifty, you toad sucker!
Re: b-body 833
[Re: DennisH ]
#785217
08/27/10 08:24 PM
08/27/10 08:24 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
Tremec TKO 5-Speed.
huh ???
Re: b-body 833
[Re: JohnRR]
#785218
08/27/10 08:44 PM
08/27/10 08:44 PM
Posts: 905 SD
zrxkawboy
SD
Thanks for the reply, John. So if I understand, with a '70-up trans, I'd need a trans crossmember for a '70-up car?
Re: b-body 833
[Re: zrxkawboy]
#785219
08/27/10 08:57 PM
08/27/10 08:57 PM
JohnRR
U.S.S.A.
No not really, an automatic crossmember for a 66-69 B body is what you need with a 70-74 B/E. Starting in '70 the automatic and 4 speed used the same crossmember.
