Intermittent Starting Issue ?
#78244
06/22/08 09:38 AM
06/22/08 09:38 AM
Posts: 114 USA
stan1970
USA
Hello All,
I've had a strange starting issue on my '70 Coronet (4-speed car) that has happened only a few times, but I'm puzzled as to what might be the cause.
This has only happened to me a few times over the course of the last couple of years. I will go to turn the key and I get no sound at all. Completely quiet - no clicks. I have battery power - the interior lights, headlights, etc all are working. And when I turn the key - the Parking Brake light, reverse light, etc all are getting power as they light up. But not a sound from the starter. I even get that buzzer when I open the door - so it knows my key is in the ignition.
I can then keep trying to start the car over and over - nothing - no sound at all. Then, I wait maybe 10-15 minutes and come back - and I try again - it cranks over as stong as ever and fires right up.
And it will then go for months without this happening again.
Does anyone have any pointers on what could be happening here? Does this sound like a wiring issue to the starter or starter relay? Or the starter or starter relay itself? Or possibly ignition switch? When I turn the key, I do get the idiot lights - so somehow it seems to know the key is in and being turned.
As I said, this only happens like 1 out of maybe a 100 times... but I am really curious as to what it might be!
Thanks much for any pointers on this. I know these intermittent problems are the hardest, but maybe someone out there has seen something like this before.
--Stan
Re: Intermittent Starting Issue ?
[Re: stan1970]
#78245
06/22/08 11:04 AM
06/22/08 11:04 AM
Assuming you are correct about "no sound at all" these are the possibilities:
Do you still have the clutch safety switch? That or it's associated wiring could be the problem.
The very FIRST thing I'd do, if you have it, is pull the wire from the firewall relay which goes to the clutch switch, and ground it. Just make up a short little jumper from the relay push-on term. to ground.
Bad firewall mounted starter relay
Corroded/ loose firewall harness connector
Connector on rear of ignition switch
Bad ignition switch
any or all "wire crimps" in between
#78247
06/22/08 03:10 PM
06/22/08 03:10 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Sounds to me like the ae old problem of corroded battery terminals and that should be the first place to look (KISS). Take the cables off the post and wire brush or use a terminal cleaning tool and clean both the posts and ther terminal clamps to a shiny clean. Maks sure that the terminals clamp down tight to the posts when done and that you can not turn them on the terminal by hand If you can an easy fix for that is to take out the olt and clamp the terminal together with a vise grips or put the terminal in a vise and cut through the mating surface with a hack saw making it able to clamp tighter. Reason there is lights etc is they don't draw near as much as the starter.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: stan1970]
#78251
06/23/08 10:46 PM
06/23/08 10:46 PM
The clutch safety switch--if your car has it, requires you to push down the clutch pedal to start the car, and works just like the neutral safety switch for an auto trans
Here's how it works. The older (69) cars with a stick had THREE terminals on the firewall mount starter relay.
The largest stud goes to battery
The other exposed screw goes to the starter
(Jump those two to crank the engine)
The third "push on" terminal goes to the "start" position of the ign switch, and engages this relay for start
Additionally, if you have an auto trans, or the "clutch start switch" there will be a FOURTH wire--a push on connector--on the relay.
With an auto trans, this wire is grounded when the trans is in neutral or park, allowing the relay to operate
With a stick, and the "clutch start" switch, you push down the clutch and that switch grounds that relay terminal.
My book shows the wire to the clutch as a separate (push on, dark green) going through a firewall grommet by itself. To test, remove the push-on wire from the relay, and GROUND that relay terminal. The car should crank
If not, see if the other push on get's power when the ign switch is in "start." If you have power there, and the relay does not pull in, you have a bad relay.
One of the first things I did when I got my '70 RR was to bypass that clutch switch.
[Re: stan1970]
#78253
06/24/08 10:30 PM
06/24/08 10:30 PM
It's been a long time since I owned one, but I recon so.
Next time it won't start, put the car in neutral, and cycle the clutch pedal up/down. The clutch switch may be going bad.
If not, try not to bump things, and carry a "clip lead" with you. Pull off that green wire, and hook the exposed terminal on the relay to ground, then see if it cranks with the key
If not, it may be the relay
Again, in an emergency, just put a coin, key, or other metal object across the two exposed terminals and it should crank.
