Page 1 of 4 1 2 3 4
HEI module...*updated, success!* #779085
08/20/10 06:46 PM
08/20/10 06:46 PM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
Ok, now don't start hatin on me for thinkin it, but...I am fixing to install a GM HEI module on my truck *gasp* I was wondering if anybody else has done it, and do ya have pics? The wiring looks like it is very straightforward, and it will clear some clutter and simplify my wiring harness and hopefully ease the engines electrical needs.... don't be embarressed if you have GM parts on yer mopar! How did you mount it? Are you using a heat sink? Did you retain your original as a backup? Or did you remove your ECU system completely (which is what I'm thinking of doing)?
Re: HEI module... [Re: '84 D150 Shorty] #779086
08/20/10 08:39 PM
08/20/10 08:39 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Crisp, Clean, and no Caffiene.
If you do not want to spend the money for the excellent FBO system, this is a strong second choice. The way to make a start stand ignition stsyem too. Works super.
link page
Re: HEI module... [Re: '84 D150 Shorty] #779087
08/20/10 09:57 PM
08/20/10 09:57 PM
Mount it on a piece of aluminum plate w some dielectric clear grease in between for the heat sink (required). Some one either on here or eGay sells a plate to mount it under the dist for twenty some dollars but just make your own & bolt it to the bottom of the dist & yes mounting it under the dist is the perfect place for it. The one I originally used was one from a '75 chebby 350 eng w the 4 identical 1/4" male terminals.
Re: HEI module... [Re: RapidRobert] #779088
08/21/10 01:03 AM
08/21/10 01:03 AM
TN
Pickup Man
Pickup Man
TN
Mounting under the dizzy sounds perfect! Got any pics of yours?
Re: HEI module... [Re: '84 D150 Shorty] #779089
08/21/10 01:25 AM
08/21/10 01:25 AM
No I didn't take pics of the 1st one (440) way back and I dont have this SB one finished yet (gettin close though)
Re: HEI module... [Re: RapidRobert] #779090
08/21/10 09:25 AM
08/21/10 09:25 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Working on this, and have done a lot of research.
Slantsix.org has a great page with lots of info.
http://www.slantsix.org/forum/viewtopic.php?t=28732&highlight=hei
Use the links in the first post for more info and parts list. I have about $80 invested and on my third design of a coil mounting bracket. I would like it to fit in the stock location. And might mount the HEI where the the ballast resistor was.
I am tired of not being able to get parts at any parts store, (We have to order that). I want reliability so I can drive my cars any where.
Adding relays for the head lights was the second best improvement To any old mopar in my opinion. First is having the steering box rebuilt by steer and gear.
Re: HEI module... [Re: convx4] #779091
08/21/10 02:40 PM
08/21/10 02:40 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Easy.
Re: HEI module... [Re: mark7171] #779092
08/21/10 11:35 PM
08/21/10 11:35 PM
TN
Pickup Man
Pickup Man
TN
Ahhh.... I see! Very cool! Out of sight out of mind, I like that! Cant wait to do this mod!
Re: HEI module... [Re: '84 D150 Shorty] #779093
08/22/10 01:29 AM
08/22/10 01:29 AM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
Yea, slantsix.org has this fully covered. Here's the best page on that site.
http://slantsix.org/forum/viewtopic.php?t=15779
I made the unit below for my 73 Dart. It was wired like explained on slantsix including the relay. Notice the heatsink underneith and the electic grease under the module. Important stuff. Some guys just bolt the module to the inner fender to act as a heatsink, but I burned a few that way. This heatsink was adopted from a computer CPU heatsink.
Worked great, if a little ugly (that can be fixed), and I've always copied it in every Mopar I've owned since.
Re: HEI module... [Re: '84 D150 Shorty] #779094
08/22/10 02:20 AM
08/22/10 02:20 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
In 1984-85 when doing this mod,I simply mounted the HEI in a position to gain a little airflow,not a big deal really.
Re: HEI module... [Re: goldmember] #779095
08/22/10 03:57 AM
08/22/10 03:57 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
My setup does not melt down after the vehicle warms up. The HEI has been in service for years. People like to use the MSD AL mounting plate for a clean look. Never seen that much heatsink on a 4 pin. That melting only happens in extreme cases, and mistakes.
Re: HEI module... [Re: mark7171] #779096
08/22/10 04:18 AM
08/22/10 04:18 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
All the good information has been posted regarding the HEI swap. What I will post is that di-electric grease should not be used between the HEI module and the heatsink. Thermal paste should be.
Re: HEI module... [Re: Pat_Whalen] #779097
08/22/10 03:40 PM
08/22/10 03:40 PM
I stand corrected as yes you are transfering heat not voltage (the 2 mounting screws ground it). Who/what/where can I get thermal paste for this one I'm doing and since I only need a wipe of it on this one module what kind of shop uses it so if need be I'll hit them up for a slight amt.
Re: HEI module... [Re: RapidRobert] #779098
08/22/10 08:48 PM
08/22/10 08:48 PM
Raleighwood
2Bad360sfromNC Offline
Raleighwood
I've done this on my old Valiant, and on my Challenger. I have always just mounted them to the inner fender, and so far have never even had one get warm to the touch.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D)
1974 Challenger 360
2012 Challenger R/T
1991 Dakota 5.2
Re: HEI module... [Re: 2Bad360sfromNC] #779099
08/22/10 09:07 PM
08/22/10 09:07 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
Over the weekend did some work on this. I wanted to take the advantage of the E-coil and not just the HEI module. It took me three tries to get a bracket that would fit and still leave some access. I mounted the E-coil in the same location as the factory coil. I was going to re curve my distributor after the modification was done, so I didn't want to mount the HEI to it. So I made a mount on the front of the coil. I still have some wiring to complete before I test this out.
Re: HEI module... [Re: convx4] #779100
08/22/10 11:20 PM
08/22/10 11:20 PM
70duster340 Offline
70duster340  Offline
Does this conversion work on early model Mopars, such as a 1970 Duster? Is it a better setup than the stock electronic ignition with the chrome box?
Re: HEI module... [Re: 70duster340] #779101
08/22/10 11:40 PM
08/22/10 11:40 PM
yes, just need an electronic dist to trigger it and Jacobs ign says that it is the only ECU that electronically increases the dwell time as the rpm increases and supposedly it was (in part) developed by some retired NASA space scientists in the early 70's
Re: HEI module... [Re: RapidRobert] #779102
08/23/10 12:10 AM
08/23/10 12:10 AM
70duster340 Offline
70duster340  Offline
So, it does away with the ECU and ballast resistor? Sounds like it would really clean up an engine bay this way!
Re: HEI module... [Re: 70duster340] #779103
08/23/10 09:22 AM
08/23/10 09:22 AM
((1) correct (2) yes it does
Re: HEI module... [Re: RapidRobert] #779104
08/23/10 09:54 AM
08/23/10 09:54 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Here is a source for one of the "better" thermal pastes out there:
http://www.amazon.com/Arctic-Silver-Polysynthetic-Thermal-Compound/dp/B002CZAPUQ
Page 1 of 4 1 2 3 4
