Page 3 of 4 1 2 3 4
Re: HEI module... [Re: kilroy] #779125
08/29/10 11:21 PM
08/29/10 11:21 PM
Can someone explain the ohms need on a coil? there is a .25, .5, and 1.5. I would like to use one of the hot ecoils but I dont understand which ohm I should use. Im using electronic ignition w/ chrome box.
the gold drag race only ECU is recommended (by MP) to use a .25 ballast and the orange/chrome kits have a 1.25 ohm ballast.
Re: HEI module... [Re: kilroy] #779126
08/30/10 01:20 PM
08/30/10 01:20 PM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
You can use the late model coils, for example, a coil for a 92 dodge truck would work perfectly, and would eliminate the ballast
Re: HEI module... [Re: 70duster340] #779127
08/30/10 01:24 PM
08/30/10 01:24 PM
TN
Pickup Man
Pickup Man
TN
Can anybody advise of any brackets that may be available for the e-core coil to be mounted in the stock location?
You'll have to get a E-core coil bracket and then modify it
I am in the middle of doing this swap today....will post pics
Re: HEI module... [Re: '84 D150 Shorty] #779128
08/30/10 01:33 PM
08/30/10 01:33 PM
70duster340 Offline
70duster340  Offline
Excellent, sir! I appreciate it!
Re: HEI module...*updated, done!* [Re: '84 D150 Shorty] #779129
08/31/10 10:21 AM
08/31/10 10:21 AM
TN
Pickup Man
Pickup Man
TN
OK folks, its now (for me) no longer a can it be done topic, but a "i dunnit" topic lol. After several hours of painstaking work, The truck is running on the HEI module....and let me say, wow. I wasnt sure that it would make a huge difference, but it did! Acceleration is is crisper, idle is better (i actually had to turn the idle down a tad!), and over all just feels more responsive! If you decide to do it, you be the judge. Now, on to how i dunnit. First things, first. The parts. I decided I was going touse an e-corecoil, because i wanted maximum benefits. I decided on a coil from a 1996-2000 chebby pickup or SUV because it has a a bracket, and a mounting place with a heat sinc for the module ($25 at the wrecking yard))! I installed an MSD HEI module that a buddy gave me (free, but you can get an HEI moduleat O'Reilly's for $25). And of coarse, wiring connectors and other realted supplies. My install is a little more involved because of the setup i chose, and because i modified (or simplified actually) my engine harness. I decided come hell or high water, this was gonna work, and i removed the wiring for the ballast resisitor and the ecu, as well as the original coil wires. You dont have to do this, you can choose to leave your original wiring just in case.
Re: HEI module...*updated, done!* [Re: '84 D150 Shorty] #779130
08/31/10 10:24 AM
08/31/10 10:24 AM
TN
Pickup Man
Pickup Man
TN
Ok now for pics (if you decide to use a canistor coil, some of this obviously won't apply):
This is the coil with bracket, and module heat sink i got:
Re: HEI module...*updated, done!* [Re: '84 D150 Shorty] #779131
08/31/10 10:27 AM
08/31/10 10:27 AM
TN
Pickup Man
Pickup Man
TN
The module on the 1996 chebby is a bit different, so some modification is neccassry. The mounting holes on the 4-pin module are the same, but one the heat sincs fins will have to be removed:
After removal:
Re: HEI module... [Re: RapidRobert] #779132
08/31/10 10:29 AM
08/31/10 10:29 AM
TN
Pickup Man
Pickup Man
TN
Also the locator nubs on the module will have to be removed. The nub:
Removed:
Re: HEI module...*updated, done!* [Re: '84 D150 Shorty] #779133
08/31/10 10:32 AM
08/31/10 10:32 AM
TN
Pickup Man
Pickup Man
TN
When mounting the module, Its important to use the thermal grease. So have gotten away with not using it, but i am looking for longevity, so i recommend it. I put some on the bracket part of the mount:
and on the module:
Re: HEI module...*updated, done!* [Re: '84 D150 Shorty] #779134
08/31/10 10:34 AM
08/31/10 10:34 AM
TN
Pickup Man
Pickup Man
TN
With module assembled, this is what it looks like:
Re: HEI module...*updated, done!* [Re: '84 D150 Shorty] #779135
08/31/10 10:37 AM
08/31/10 10:37 AM
TN
Pickup Man
Pickup Man
TN
Then I added my relay (also not required, but recommended). I simply drilled out one the aluminum rivets that hold the coil to the bracket, and put a bolt through to the relay. Makes for a nice "all-in-one" unit!
Re: HEI module...*updated, done!* [Re: '84 D150 Shorty] #779136
08/31/10 10:41 AM
08/31/10 10:41 AM
TN
Pickup Man
Pickup Man
TN
For connectors, i obtained the sealed connector for the coil when i when to the junk yard, and these GM alernator pigtails I got at Autozone for $3 areperfect. I got two of them. You'll notice one of the pins of the module is smaller thanthe rest, but with the connectors, i used, it doesnt really matter:
Re: HEI module... [Re: '84 D150 Shorty] #779137
08/31/10 10:45 AM
08/31/10 10:45 AM
TN
Pickup Man
Pickup Man
TN
Ok, now, the COIL WIRE. This can be tricky! The coil I chose has a VERY UNIQUE plug-in. I ended up buying and ENTIRE set of plug wires for a 1996 chebby truck, and then getting some wire ends from Accel and modifying one (i have extra wires if ya need lol). With my modified wire, these are the ends now:
Re: HEI module...*updated, done!* [Re: '84 D150 Shorty] #779138
08/31/10 10:52 AM
08/31/10 10:52 AM
TN
Pickup Man
Pickup Man
TN
Next i started wiring it up. I will post a schematic for my set up here shortly. Here we see it slowly taking shape (Important note: You need a good ground for both the module and the relay. I ran a wire from the ground pin on the relay to a mounting screw on the module. This grounds the relay through the module, and the module is grounded through the bracket. To ensure the bracket grounds properly, i sanded the paint off the mounting holes, so when bolted down, it would be grounds good)
Re: HEI module... [Re: '84 D150 Shorty] #779139
08/31/10 10:54 AM
08/31/10 10:54 AM
TN
Pickup Man
Pickup Man
TN
This the module to distributor pigtail i made up:
Re: HEI module... [Re: '84 D150 Shorty] #779140
08/31/10 10:57 AM
08/31/10 10:57 AM
TN
Pickup Man
Pickup Man
TN
This is my firewall/coil setup pre-HEI. As stated previously, I removed all the components for the originally setup, and modified my wiring harness, but you dont have to do that.
Re: HEI module... [Re: '84 D150 Shorty] #779141
08/31/10 11:00 AM
08/31/10 11:00 AM
TN
Pickup Man
Pickup Man
TN
after installing the HEI "component":
And all buttoned up and running (actually, its was running when i snapped the pic :
Re: HEI module... [Re: '84 D150 Shorty] #779142
08/31/10 11:01 AM
08/31/10 11:01 AM
TN
Pickup Man
Pickup Man
TN
Ok, now for the wiring details.....gimme a bit while i get all the details gathered up....
Re: HEI module... [Re: '84 D150 Shorty] #779143
08/31/10 04:45 PM
08/31/10 04:45 PM
TN
Pickup Man
Pickup Man
TN
Ok, here is the diagram for MY setup. You may have to tailor to suit your needs:
And here is a basic simplifed version for those desiring to use a canistor style coil. I want to reaffirm one detail. If you use a .5 ohm canistor coil, to keep from cooking the coil you MUST use a ballast resistor. If you use the late model coil from a "lean burn" system you don't need the ballast. Some have gotten away with not using the ballast on the .5 ohm coils, but it is NOT advisable! Ask me how I know!
Re: HEI module... [Re: '84 D150 Shorty] #779144
08/31/10 05:49 PM
08/31/10 05:49 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
very good info.. I want to this on my 87 RC. wanna do it again?
I am truckless..
Page 3 of 4 1 2 3 4
