Which intake.... #776291
08/18/10 12:09 AM
08/18/10 12:09 AM
Ohio
Chad Bittle Offline OP
Ohio
...between the M1 4150 and M1 4500???
Have read that a M1-4150 flows better then the 4500, but still no power comparisons.
Re: Which intake.... [Re: Chad Bittle] #776292
08/18/10 12:10 AM
08/18/10 12:10 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
If you have room...many think the m1 4150 with a dominator adapter is the way to go.
Re: Which intake.... [Re: Quicksilver440] #776293
08/18/10 12:29 AM
08/18/10 12:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You gain more plenum volume going this way
Re: Which intake.... [Re: Quicksilver440] #776294
08/18/10 12:32 AM
08/18/10 12:32 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Re: Which intake.... [Re: sixpakdodge] #776295
08/18/10 10:55 AM
08/18/10 10:55 AM
Ohio
Ohio
Alrighty, thanks for the info guys. Have the option to use either one. This is going on a 451 with a Dominator carb, so wanted to know what our best bet would be.
Re: Which intake.... [Re: Chad Bittle] #776296
08/18/10 12:36 PM
08/18/10 12:36 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I am running a stage 6 m1 4150 with the adaptor and have been looking for a m1 4500 to get rid of the spacer but am I really better off with the spacer? I might have to go to a bigger scoop since I cant fit a air cleaner on it now with the 4" hemi scoop.
67' charger 499 RB 10.57 at 127
Re: Which intake.... [Re: Chad Bittle] #776297
08/18/10 12:42 PM
08/18/10 12:42 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Can you test both of them before making a decision? From a simple flow perspective, the 4500 version is better (based on my testing years ago). However, the 4150 + adapter / spacer combination may (repeat MAY) still work better. But there's only one way to know...
Re: Which intake.... [Re: BradH] #776298
08/18/10 01:12 PM
08/18/10 01:12 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I cant test. My 4150 intake is ported and also had some angle milling on the flanges so it would be a job to buy the 4500 and have all the work done to it to try it out.
