71 Cuda road lamp bracket install ? #773520
08/14/10 11:53 AM
08/14/10 11:53 AM
USA
K
krw71ragtop Offline OP
K
USA
I purchased a road lamp kit and I'm not sure if I need this bracket to install them ? Looks like all I need to do is remove the 2 bumper bolts and mount the lamps where the bolts were. Anyone have some pictures on the installation or advice on how to mount them ? Thanks
Re: 71 Cuda road lamp bracket install ? [Re: krw71ragtop] #773521
08/14/10 01:36 PM
08/14/10 01:36 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the curved part of the bracket fits behind the bumper and bolts to a bumper bolt..the other bolts to the bumper bracket..the hole with the concaved part is where the lamp assy bolts to....don't forget left and right bracket...
Re: 71 Cuda road lamp bracket install ? [Re: AARCONV] #773522
08/14/10 02:05 PM
08/14/10 02:05 PM
USA
K
K
USA
Thanks, I think I got it now.
Re: 71 Cuda road lamp bracket install ? [Re: krw71ragtop] #773523
08/14/10 02:26 PM
08/14/10 02:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 71 Cuda road lamp bracket install ? [Re: Alaskan_TA] #773524
08/14/10 03:19 PM
08/14/10 03:19 PM
USA
K
K
USA
Re: 71 Cuda road lamp bracket install ? [Re: krw71ragtop] #773525
04/10/11 06:25 PM
04/10/11 06:25 PM
SK, Canada
CA71CUDA Offline
CA71CUDA  Offline
SK, Canada
I have a 71 cuda and am installing the road lamps that were originally on the car.
The brackets I got are the exact ones in the picture (for a 71) however when bolted to the bumper bolt, the other bolt hole that is supposed to line up with the hole in the frame is not even close. It would require allot of bending and that may not even do it.
Has anyone esle had this problem and what did you do?
