Plugging oil pick up port??? #769299
08/09/10 12:13 AM
08/09/10 12:13 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
When changing from stock oiling system to an external line system with a swinging pick up, where is the best place to plug the stock pick up port in the block. In the crankcase, where to stock pick up was unscrewed from, or in the block behind the oil pump. Any other modifications need to be done?
Thanks, Brian Dunnigan
Re: Plugging oil pick up port??? [Re: '72CudaRacer] #769300
08/09/10 01:08 AM
08/09/10 01:08 AM
iowa
wesw Offline
wesw  Offline
iowa
you have the pan off to remove the pickup tube
just screw a flush mount plug into it and your done.
598 ci predator
Re: Plugging oil pick up port??? [Re: wesw] #769301
08/09/10 07:16 PM
08/09/10 07:16 PM
Mooresburg, Tn
Mooresburg, Tn
Thanks Wes. I was hoping that would work, because I haven't found a plug to fit the one behind the oil pump.
Brian Dunnigan
Re: Plugging oil pick up port??? [Re: '72CudaRacer] #769302
08/09/10 07:49 PM
08/09/10 07:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
And if you run a dual line system you don't need to plug either or them.
