Re: oil and temp send unit
[Re: bboogieart]
#767743
08/08/10 09:17 PM
08/08/10 09:17 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
pic #5 the canister for the oil pressure gauge. It screws right in where the other sender goes. Same size threads. Man look at how old that box is. Hmmm wonder how long I had that on the shelf. Hope this helps.
This is the sender you will need for an oil gauge. It goes in the back of the block on the drivers side as you said but can actually go on either side to suite you.
[Re: mopar70charger]
#767745
08/08/10 09:20 PM
08/08/10 09:20 PM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
I believe I even had one that the small hole was on top.Just look for a purple wire at the front of the block with I believe an angled connector on it.Thats the single wire for the temp.Rocky
Chrysler Firepower
[Re: stumpy]
#767751
08/09/10 08:02 AM
08/09/10 08:02 AM
therocks
Niles , Ohio
Yeah Ma used about the same lengths of wires and color codes also.The only time you run 2 oil senders is when you have Sgnal Sentry type dash like Imperials had.They had both gauge and light.Same with the temp senders.Imps had gauge and a hot light at least my69s amd 70s did.Rocky
Chrysler Firepower
[Re: therocks]
#767752
08/09/10 10:15 AM
08/09/10 10:15 AM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
the rule of thumb says 1967-1976 V8s with GAUGES A,B,E body use the bell type oil pressure switch, and the small brass temp sender...pictured here....industry standard part#s
OIL PRESSURE SENDER AMPCO PS32, NIEHOFF AL133R,STANDARD PS59,ECHLIN OP6603, FILKO OP58X, BORG WARNER S330
TEMP SENDER AMPCO TU22, NIEHOFF FF134E,STANDARD TS17,ECHLIN TS6178, FILKO 2030, BORG WARNER WT127
