Does Anyone Know Of A 13" Drop Base For Air Filter?? *DELETED*
#76752
06/20/08 11:36 PM
06/20/08 11:36 PM
Posts: 1,019 Eau Claire, WI
ResQ911
super gas
super gas
Eau Claire, WI
Re: Does Anyone Know Of A 13" Drop Base For Air Filte
[Re: 6T6Cuda]
#76755
06/21/08 11:12 AM
06/21/08 11:12 AM
Posts: 74,937 U.S.S.A.
JohnRR
U.S.S.A.
[Re: JohnRR]
#76756
06/21/08 11:43 AM
06/21/08 11:43 AM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
linky
Thanks JohnRR - now we will have to fight with the Ford guys to get it...
[Re: JohnRR]
#76758
06/22/08 04:00 PM
06/22/08 04:00 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
There is a problem with using the FMS base in conjunction with a (Mopar) stock top. The choke horn comes very close to the lid and it's really restrictive. Due to the contour of the lid, you end up with about a 3/4" clearance from lid to base at the narrowest point.
If you run a carb without a choke horn, you'd probably be okay, but the 3/4" clearance is still pretty tight.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#76759
06/22/08 04:11 PM
06/22/08 04:11 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
There is a The problem with using the FMS base in conjunction with a stock top. The choke horn comes very close to the lid and it's really restrictive. Due to the contour of the lid, you end up with about a 3/4" clearance from lid to base at the narrowest point.
i noticed a change in power when i went from my MP with a dropbase, to my factory style 'snorkel' air cleaner with more area around the carb.
[Re: 471Magnum]
#76760
06/23/08 08:50 AM
06/23/08 08:50 AM
JohnRR
U.S.S.A.
since i never picked up the one my friend has to look i never got the chance to check that , thanks . K+N does have taller air filter elements , but that might defeat the purpose of the drop base ?
i'll stop recommending that one .
