power steering pulley confusion #76514
06/20/08 02:13 PM
06/20/08 02:13 PM
Southwestern PA, Scumerset
gfriedline Offline OP
super street
super street
I recently Changed the pulleys on my Small block from A/C to chrome non-A/C with power steering. I thought the original PS brackets and pulley would be correct, however, the change to an aftermarket, 2-groove Crank pulley and PS pulley caused a large offset in the pulleys between the crank and PS pulley. The PS pulley sits about 3/8" too far foreward to match the crank pulley correctly. The water pump and alternator pulleys lined up perfectly.
Any pictures or ideas on this? I have the oval shaped, keyway type pump. Perhaps I have the brackets on incorrectly, or I am just using the wrong pulleys or brackets. Any pictures or ideas? I can get a picture of this situation if need be.
70 Challenger Rustbucket 318 .030 over, #302's ported by Ryan Johnson
Re: power steering pulley confusion [Re: gfriedline] #76515
06/20/08 02:42 PM
06/20/08 02:42 PM
Andrewh Offline
Andrewh  Offline
My bet is it is miss matched.
Most aftermarket sets are for non-a/c.
My bet is your compressor doesn't line up anymore either.
If you change the bracket to a non a/c ps bracket, I bet they line up.
Re: power steering pulley confusion [Re: Andrewh] #76516
07/14/08 05:09 PM
07/14/08 05:09 PM
super street
super street
So where can I find these brackets in the aftermarket, I looked around a little hoping Mancini would have something, sort of became confused looking, I was under the assumption that non-AC and AC cars had similair PS brackets. But it would make sense.
