8 3/4 Third Member Interchange #765016
08/04/10 04:51 AM
08/04/10 04:51 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Are the sure grip sections (the part that contains the clutches and whatnot) interchangeable between 741, 742, and 489 cases or are they different.
I.E. Could I take a 741 suregrip with 2.76 gears and remove the sure grip section and then take a 742 open with 4.10s and bolt the ring gear from the 742 on the sure grip section and put it in the 742 housing to make a 4.10 suregrip in a 742 case?
Re: 8 3/4 Third Member Interchange [Re: GTX MATT] #765017
08/04/10 05:17 AM
08/04/10 05:17 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Yup! Keep the side bearings with the suregrip,
My
Own
Personal
Adrenaline
Rush
Re: 8 3/4 Third Member Interchange [Re: Moparzrule] #765018
08/04/10 12:09 PM
08/04/10 12:09 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Alright thanks
