413 motorhome engine #76244
06/19/08 10:50 PM
06/19/08 10:50 PM
Hatfield,Pa.
bigD Offline OP
bigD  Offline OP
Hatfield,Pa.
My buddy can get a 413/auto(61k miles) from a dodge motor home FREE,guy is scrapping it. But he would have to go and haul it from bakersfield to nor-cal.Is it worth it or not( cost of gas )? D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: 413 motorhome engine [Re: bigD] #76245
06/20/08 12:21 AM
06/20/08 12:21 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
413 fine as they are or turn into a 426 by just boring o.s.
i always liked my 413 ,car is long gone but engine is in the garage waiting to be reserected !
Re: 413 motorhome engine [Re: bigD] #76246
06/20/08 12:59 AM
06/20/08 12:59 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
413 mh engine is quite different than a car one. BIG heads and waterpump housing. Perhaps an 8 bolt flywheel.
How far is this drive you are talking about?
Personally, if you can get it for less than $100 of gas and lunch money it's worth it. Even if it's just for odds and ends.
Great motor for a hauler!
Re: 413 motorhome engine [Re: dave571] #76247
06/20/08 02:59 AM
06/20/08 02:59 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
my old 72 Winnie had the 413 ind engine. it was a 6 bolt crank, but as stated above it has huge heads, funky water pump assy and a monster intake. it was a torque monster. If your buddy goes for it the only useable parts for a car app would be the block, crank(same as 440)and rods. and maybe pistons if he wants a low comp engine.... I can see a 871 blower bolted on top of one...
I am truckless..
Re: 413 motorhome engine [Re: 340SHORTY] #76248
06/20/08 10:49 AM
06/20/08 10:49 AM
dogdays Offline
dogdays  Offline
But not all motorhome 413s had the weird heads, water pumps and manifolds. Look at it this way: At 750 lb it is worth $82.50 as scrap. The transmission has heavy-duty guts although the tailshaft and housing will have to be changed to one from a car.
I say go get it. A man can never have too much cast iron aging in the back yard!
R.
Re: 413 motorhome engine [Re: dogdays] #76249
06/20/08 02:38 PM
06/20/08 02:38 PM
Haysville, Kansas
rdrmod6 Offline
rdrmod6  Offline
Haysville, Kansas
I nought a 413 motorhome engine from a motorhome a while back. It is supposed to have around 33,000 miles on itand I needed a runnung bigblock so I could move the car around under its own power. When I picked it up I was supprised at what I got. It has unique cylinder heads, exaust manifolds, distributor, oil pump drive, camshaft, and a gear drive for the cam. the dampner is also different. It also has low compression pistions, on the positive side it has a steel crank with a 6 bolt flange. as soon as I am done with the car I intend on using this for a 426, but until then I have a large stack of iron left over from the motorhome specific parts. If you have the room to store it why not? they sure are not making them anymore.
Re: 413 motorhome engine [Re: rdrmod6] #76250
07/04/08 04:53 AM
07/04/08 04:53 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
These are a low-rpm motor that as long as you keep coolant and decent oil in it ... it will never break. I would like to try my hand at making that motor a better performer .... using those heads.
Anyone with parts laying around that you want to get rid of .. let me know.
