Re: Spicer u-joint cross reference...
[Re: Wicked49670dart]
#759889
07/28/10 12:46 AM
07/28/10 12:46 AM
Posts: 19,304 Las Vegas
Al_Alguire
Las Vegas
take it into a Napa store. Any parts counter guy worth a dang can find it. IIRC the std stock type deal is 1.078 cap and 2.12 across, but dont quote me on it. And yes the number on the spicer is a casting number. Why not go back to where the shaft was built? Might be a conversion joint?!?
[Re: Jeepmon]
#759891
07/28/10 09:43 AM
07/28/10 09:43 AM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Do a search on a: Precision 347 u-joint. Summite carries this part and I am not sure its what you need but I have had this empty box laying around for the last 30 years.
Found this on another site. If the Precision 347 looks like the right u-joint.
TRW part #20226 or CR UJ347, Mancini 5-527X Auto zone 2-0527 Napa NUJ240-0369 Neapco 2-0527
[Re: pittsburghracer]
#759893
07/28/10 10:16 AM
07/28/10 10:16 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I can't believe you couldn't find a match. NAPA has a book 2" thick to look through. I did that years ago when I needed to mix and match a shaft and yoke, ended up with a ford bronco joint that had 2 different cross lengths. Try again, maybe ask for a old book or just for you to look in their counter book, so it doesn't take up their time. Auto Zone , Advanced etc. only have computers and very limited knowledge counter people. Sorry but true. Oh , by the way you might try that Bronco joint.
