Re: Aligning new trunk lid
[Re: JonC]
#75972
06/19/08 02:41 PM
06/19/08 02:41 PM
Posts: 1,261 ILL
mark7171
ILL
its the trunk spring set up. it torques the one side only, creating the lift on one side.
you can bend it (yourself or a body shop)
you can MOD it to accept differt alt stock pivots/hinges and have modern struts to stay open. i think they were using 80's honda strut stuff. some had just a shiny thin chrome pole.
[Re: JonC]
#75974
06/19/08 03:03 PM
06/19/08 03:03 PM
You have to tweek it a bit. I used a big 2 x 4 to give it a little persuasion. I installed a new trunk weatherstrip, and it made the lid sit up a little high (1/16") too. Had some basement brinks sitting on it for over a month, no change. Shaved the rubber bumppers down a little too, to see if it would help....not much. Mine now sits about 1/32" high...best I could get.
[Re: JonC]
#75975
06/19/08 03:05 PM
06/19/08 03:05 PM
Posts: 1,261 ILL
mark7171
ILL
i have not solved the problem.
if there are different positions, try to relieve the spring pressure twist, in a different notch.
other things could be up?
big Q-
does its do it with the spring removed?
[Re: mark7171]
#75976
06/19/08 03:05 PM
06/19/08 03:05 PM
Posts: 1,261 ILL
mark7171
ILL
Does it do it with the spring removed?
do you have the trunk spring removal tool?
