340/416 running hot...HELP #75758
06/18/08 10:08 PM
06/18/08 10:08 PM
Spartanburg SC
MoparDan Offline OP
MoparDan  Offline OP
Spartanburg SC
I've got a sb 416, new everything, re-cored, wider than stock, 3 core 26" radiator; running a factory shroud; new thermostatic fan clutch which I tested using the "3/4 tape test",- the fan seems to be turning fine. the fan blades are seting about 1 3/4 inch away from the radiator. there is a cleared, fins streightened, condensor and a new trans cooler in front of the radiator. new, if I remember correctly, 180# thermostat which I drilled two small holes to allow water flow. Theromostat is opening and closing. running a 50/50 mix with temp-cooler poured in. Engine is timed at about 35/36 degrees all in at about 3000 rpm.
The car has a factory temp gauge, which seems to be reasonably accurate. The problem is when I get the car crusing after about 5-6 miles the temp gauge is midway between hot and cold. Then creeps up a little more, just past midway...stays there then I get it home... idleing it begins to creep up toward hot...I shut it off. I can feel the water at a fast-boil when I feel the (hard) upper radiator hose. Header temps will vary between 400 and 1000+ (at #6, previously just after break-in #4 and #6 would be starting to glow! now they are down to 6-700)
Could there be a blocked water passage? The engine was nasty in a barn for a while when I got it. The machine shop, (who's attention to detail I seriously question) cleaned it and bored it as well as rebuilt the heads. The engine builder has no clue. I have had the car running about a year, during which time I have maybe put 40 miles on it due to hot header temps and now overheating worries. Any suggestions are welcome! Please help.
Re: 340/416 running hot...HELP [Re: MoparDan] #75759
06/18/08 10:31 PM
06/18/08 10:31 PM
Millersville, PA
HemiChallenger Offline
Millersville, PA
This is very common with strokers on small blocks. They overheat all the time. I have not seen anything much that you can do beside pulling the thermostat completely out to keep temps low but i dont know how you feel about that.
Re: 340/416 running hot...HELP [Re: HemiChallenger] #75760
06/18/08 10:43 PM
06/18/08 10:43 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Here's what I have for my 416. Griffin aluminum Max Cool nascar type 26" radiator. Factory shroud. Thermo fan clutch. 7 blade aluminum(painted black) fan out of some huge Chrysler made car at the junk yard(Dodge Monaco I think). High flow water pump from Mancini but don't remember the brand. March overdriven serpentine pulleys. Factory style rad hoses. 160* high flow thermostat. I can drive my car in Death Valley if I choose. Normal cruising doesn't ever get above 160. -Bob
Re: 340/416 running hot...HELP [Re: HemiChallenger] #75761
06/18/08 11:15 PM
06/18/08 11:15 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I know somebody who has one in a 65 cuda with the stock factory 273 spec radiator, a small flex fan and no shroud and it never gets too hot.
