Rear brake backing plate gaskets/ shim question #75747
06/18/08 10:04 PM
06/18/08 10:04 PM
Dexter, Michigan
copper67440 Offline OP
mopar addict
mopar addict
Dexter, Michigan
I am building up the rear brakes, and can't remember or find in the service manual a clear order in which the foam gaskets and steel shim gasket go on. 67 8 3/4 11" ?
Re: Rear brake backing plate gaskets/ shim question [Re: copper67440] #75748
06/18/08 10:12 PM
06/18/08 10:12 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
1. Housing end
2. Beaded steel gasket
3. Brake backing plate
4. Foam gasket
5. Wheel bearing retainer
Re: Rear brake backing plate gaskets/ shim question [Re: DoctorDiff] #75749
06/18/08 10:34 PM
06/18/08 10:34 PM
Dexter, Michigan
mopar addict
mopar addict
Dexter, Michigan
Thanks Doc, I may be calling you for a ring and pinon,
