LA / Magnum hyybrid #756343
07/24/10 12:48 AM
07/24/10 12:48 AM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
A previous topic has sparked some interest for me to do a hybrid motor...so, after digging through the archives I found some great info on doing a flat tappet LA hybrid. I however want to do a roller version. I have an 86 roller LA motor. Does anybody know: will the stock Magnum valve train work in the roller LA? If I get Mag heads, can I use the Mag heads, can I use the Mag pushrods and roller lifters in the roller LA block? If so, are any mods necceassary or will the parts drop right in? It is enticing to bolt the better breathing and smaller chamber Mag heads on my lethargic 318 to wake it up....for dirt cheap! If anybody has done this, please. Please share info pics or whatever!! I really wanna try this!
Re: LA / Magnum hyybrid [Re: '84 D150 Shorty] #756344
07/24/10 09:09 AM
07/24/10 09:09 AM
TN
Pickup Man
Pickup Man
TN
Ok, got these questions answered in another post by scratchinfotraction (thanks mike you da man!) But I want to keep this post alive so I can do an illustrated how to, so if your interested, mark this post in your favs and keep your eyes peeled
Here's what I got and what I'm gonna do: I have an 86 LA 318 with a factory roller cam. I am to going to swap my LA heads for Magnum heads.
Parts list:
Mag heads, complete with rocker assemblies
Mag push and roller lifters (need these because my LA does not lubricate through the lifter and pushrod)
Mag intake
New roller cam (I could keep the stock one but I wanna upgrade to a better cam)
This should allow me to use everything I already have and upgrade my cam and heads for minimal cost. The parts hunt will begin this week. I will post pics of the parts as well as estmated costs
Re: LA / Magnum hyybrid [Re: '84 D150 Shorty] #756345
07/24/10 11:55 AM
07/24/10 11:55 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
When your valve job is done, have a deep 70* cut into the head if you are using OEM magnum heads. There is a fair restriction to breathing there below the valve seat that can easily be removed.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: LA / Magnum hyybrid [Re: '84 D150 Shorty] #756346
07/25/10 08:09 AM
07/25/10 08:09 AM
scratchnfotraction Offline
watch the lift and coil bind on the mag stock springs..they wont take much lift
maybe patrick will chime in on the GM 3100 behive springs and 2.2 retainer swap and how much lift/coil bind specs are
Re: LA / Magnum hyybrid [Re: scratchnfotraction] #756347
07/25/10 10:44 AM
07/25/10 10:44 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
best bet are hughes 1110 springs and 2.2L retainers with oem mag locks...that'll give about .520-.540" lift capability with stock heads
2017 Grand Cherokee Overland
Re: LA / Magnum hyybrid [Re: patrick] #756348
07/25/10 03:02 PM
07/25/10 03:02 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
And with that much lift, you'll need to have the valve guides cut down some. I wouldn't even fool with the stock Magnum valve springs. Even though they are bee hive, they are very wimpy. I think they float with the stock cam at high revs.
Re: LA / Magnum hyybrid [Re: GO_Fish] #756349
07/25/10 06:45 PM
07/25/10 06:45 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
actually, IIRC, I had about .560" clearance between the guide and the keeper on mine, which would make .540" the most I'd consider (.020 clearance). if you went strictly by .030 less than coil bind, I could run up to .550" on my heads.
