"over-boost" from a new disc brake booster?
#75615
06/18/08 07:08 PM
06/18/08 07:08 PM
Posts: 7,052 Madera, CA.
MowP4rsn
Madera, CA.
I didn't know such a condition could exist, but can it? The new booster that was put in my 300 seems to allow the fronts to be REALLY "touchy" to brake pedal pressure, and there is a slight hiss heard from the under dash area (which was there before when the original power drum set up was still in place....not sure if it is booster or vacuum leak from the A/C switch). Since it's been a decade *at least* since I've done brake work/had to use diagnosis on a brake system, does it seem reasonable that the "new" booster is faulty? In the good news column, swapping out the rebuilt OE AFB to the reman 750 Edelbrock AFB has eliminated the stumble when the throttle is goosed !
Re: "over-boost" from a new disc brake booster?
[Re: MowP4rsn]
#75616
06/18/08 08:07 PM
06/18/08 08:07 PM
hmmmmm. i assume you do not have a adjustable proportioning valve, so did you convert from drums to your current disc brake setup?
#75617
06/18/08 09:30 PM
06/18/08 09:30 PM
MowP4rsn
Madera, CA.
Yes, and a hold off valve was also installed into the system. The MC is for a '73 T&C disc/drum. The booster is from Rock Auto, a rebuilt unit that they spec is for '68 C-body even though it is visually different from what they show (the B-body Hemi car/Disc brake unit vs what I received There is about 1/4" take-up before the brakes apply, but the fronts apply HARD and NOW when I tried them doing a forward and backward brake test at VERY low speed.
[Re: Andrewh]
#75619
06/19/08 12:02 AM
06/19/08 12:02 AM
MowP4rsn
Madera, CA.
The brakes do release when the pedal is let up, and I don't think there is any major dragging.
I'm wondering if there isn't a problem with the booster rod being too long, since I assume there is some adjustment that can be made there. I'll see what I can find for a FSM online since I left mine at the shop. The other thing I can do is measure the length of the old rod from the drum booster assembly since that is in the back of my Armada.
I just found this nugget on the Online Imperial Club's site; Question from Don (1968):
My problem is the front brakes don't release-I don't know what the rear brakes are doing but definitely the fronts won't release. Today I parked the car in my driveway which has a substantial slant to it. I put the car in NEUTRAL and I could not budge it. I put it back in PARK, separated the master cylinder from the booster and put the car in NEUTRAL and it started to roll down the incline unassisted. I put it back in PARK, reconnected the master to the booster and put it in NEUTRAL one more time-it would not move! So, is there a push rod adjustment somewhere or am I looking at this illogically?
From Larry:
Yes there is an adjustment to solve the problem you described. On most cars the rod from the brake pedal to the booster (it goes through the firewall) is adjustable. Some cars also have an adjustable rod between the booster & master cylinder. There should be a little free play when the pedal is all the way up. If these adjustments don't work, you may have some mismatched parts. I have seen the wrong master cylinder mounted to a correct booster and the wrong rod at the pedal.
I HOPE it is an adjustment and NOT a parts mismatch!
