71blueduster,
That would be great! I have an older version of AutoCAD (Release 14) if you can't save to that version can you saveas *.dxf?
I do not have a "stock" bezel to work with, as my '71 Dart GT has a completely different style of cluster/dash frame. I purchased a '70 Duster dash frame to use (from a Moparts member), but it is only the frame, no cluster included.
The attached shows a couple of different options I've come up with. The top one is my 1st choice right now! What do you think?
