Inside valve cover cleaning???? #75509
06/18/08 03:43 PM
06/18/08 03:43 PM
Grafton, OH
lmn6pack Offline OP
super street
lmn6pack  Offline OP
super street
Grafton, OH
Hey guys,
I glass beaded my valve covers and now I have glass bead embedded in the slime under the valve cover baffles. What do you guys do to clean under the baffles? Thanks.
Re: Inside valve cover cleaning???? [Re: lmn6pack] #75510
06/18/08 03:46 PM
06/18/08 03:46 PM
places
79powerwagon Offline
places
I use brake cleaner for darn near everything!
Re: Inside valve cover cleaning???? [Re: 79powerwagon] #75511
06/18/08 04:21 PM
06/18/08 04:21 PM
scratchnfotraction Offline
spay em down with brake clean
air dry
respray with brake clean till all is clean
cleaned them many times like this
Re: Inside valve cover cleaning???? [Re: lmn6pack] #75512
06/18/08 04:27 PM
06/18/08 04:27 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Hey guys,
You should soak and wash several times, glass beads will cake on the back side of baffles and
spot weld area folds in the steel.
You should have not used beads directly in the baffle area,If not clean throughly I don't have to tell you what happens when beads enter the engine.
logna426
Re: Inside valve cover cleaning???? [Re: MLR426] #75513
06/18/08 04:42 PM
06/18/08 04:42 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Super clean and a fish tank brush.You can get them in diff sizes and lengths to get between baffle and cover.
Re: Inside valve cover cleaning???? [Re: lmn6pack] #75514
06/18/08 04:53 PM
06/18/08 04:53 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I would consider pressure washing if you don't have a parts cleaner. Should have degreased them first.
Re: Inside valve cover cleaning???? [Re: Challenger 1] #75515
06/18/08 05:23 PM
06/18/08 05:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i would probably pull out the baffle if the glassbead was directed at the baffle it may have been forced in the crack , no amount of scrubbing is going to get it out .
Re: Inside valve cover cleaning???? [Re: lmn6pack] #75516
06/18/08 07:38 PM
06/18/08 07:38 PM
Goodyear AZ
67GeeTeeX Offline
67GeeTeeX  Offline
Goodyear AZ
Hot oil will get it out, guaranteed.
