Fender bolt repops, who? #75476
06/18/08 02:29 PM
06/18/08 02:29 PM
Elk Grove, Calif.
bigblock340power Offline OP
Elk Grove, Calif.
I'm looking for Fender bolt kits for my '71 Duster. Who has them?
Mike
Re: Fender bolt repops, who? [Re: bigblock340power] #75477
06/18/08 02:52 PM
06/18/08 02:52 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Re: Fender bolt repops, who? [Re: bigblock340power] #75478
06/18/08 02:57 PM
06/18/08 02:57 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
OE style kit or otherwise ? (if it matters )
Re: Fender bolt repops, who? [Re: gtx6970] #75479
06/18/08 03:19 PM
06/18/08 03:19 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
How can one determine the quality of fender bolts?
Re: Fender bolt repops, who? [Re: QuickDodge] #75480
06/18/08 03:33 PM
06/18/08 03:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
are you asking about OE correct such as head markings or plating finishes? or fastener strength ?
as far as I know, I'm the only one putting a OE style kit together at this time
fender bolt with 7/8" washer diam.
and 3/4" washer diam version
Re: Fender bolt repops, who? [Re: gtx6970] #75481
06/18/08 03:35 PM
06/18/08 03:35 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Durability. A fastener which will not rust and look bad after a few years of driving.
Re: Fender bolt repops, who? [Re: QuickDodge] #75482
06/18/08 03:40 PM
06/18/08 03:40 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Any bolt left unpainted will rust over time. Fender bolts are painted body color . So if your looking for something to leave as plated you might have to look at chrome or nickle plating them
