440 distributor indexing #75441
06/18/08 12:26 PM
06/18/08 12:26 PM
pgh pa
captaindodge Offline OP
pgh pa
If you still have your factory original distributor in your 440 can you see a line scribed on the base of dist that lines up with a tiny groove in the block when timing is close to the factory spec? Did the production line use this or an actual timing light?
Re: 440 distributor indexing [Re: captaindodge] #75442
06/18/08 01:16 PM
06/18/08 01:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Production did that.
Re: 440 distributor indexing [Re: captaindodge] #75443
06/18/08 04:37 PM
06/18/08 04:37 PM
I do something similar after mine is all together and timed at 36 total mechanical (vacuum disconnected).
I use a magic marker and mark the distributor base and block so I can tell at a glance if it's off.
Didn't know the factory did it. That's pretty cool!
